John Billard | 12/05/2013 14:36:17 |
42 forum posts | I am hearing that some club boiler testers are including the regulator as part of the hydraulic test and are failing boilers as a consequence. It seems to me that this is quite wrong as the regulator is not part of the pressure system. Some regulator designs are also quite diifficult to make pressure tight for this procedure. Fortunately my club testers in their discretion do not include the regulator but if they did I would be quite concerned if a carefully maintained boiler could not be cerificated for this reason. I believe that it should be made clear that the regulator is not to be included in the test. If it leaks it shold be blanked off. Kind regards John Billard
Steambuff | 12/05/2013 15:20:26 |
![]() 544 forum posts 8 photos | I am not going to comment what fittings should be part of the hydraulic test and which ones should not. But in my opinion the Regulator is part of the pressure system .... as one side of it is either in the boiler or off a bush connected to the boiler and will be at full boiler pressure. Dave
John Baguley | 12/05/2013 17:17:47 |
![]() 517 forum posts 57 photos | Under the new boiler regs (Green Book) - Following the initial 2x WP hydraulic test on the boiler shell, all subsequent hydraulic tests to 1.5x WP should be carried out with ALL fittings attached to the boiler shell. This will include the regulator if it is an integral part of the boiler and, if possible, the superheaters. If the regulator leaks slightly (as most of them do!) I would think that simply blanking off the steam pipe from the regulator should satisfy the test. The object is to check the integrity of the boiler with the fittings attached rather than whether the fittings themselves leak. Section 10.8 of the Green book refers. John |
John Billard | 13/05/2013 18:02:17 |
42 forum posts | Thank you both for your comments so far. Regarding John's comments that most regulators leak albeit slightly I believe that some testers are failing the boiler for this reason and it seems not permitting blanking off. I can't believe that is the intention of the regulations and this is what I am seeking to clarify. Kind regards John
Steambuff | 13/05/2013 18:29:07 |
![]() 544 forum posts 8 photos | All, Quote from the Green Book 10.13 Any loss of pressure shall be fully investigated. Slight loss from blanking plugs and fittings may be allowed. The boiler fittings should be examined for integrity, thread quality and dezincification to eliminate any risk of subsequent detachment. 10.14 Pressure loss which cannot be accounted for or which is at an unacceptable level shall lead to the test being declared a failure. 10.8 For all further hydraulic repeat tests, i.e. subsequent to the initial hydraulic shell test, the boiler shall be fitted with the working components attached to the boiler shell to prove the pressure and structural integrity of the interface and the boiler fittings. This includes the pressure gauge. If the gauge is not of the full range required by the test (1.5 x PW) it shall be disconnected and a blank fitted. On completion of the test (1.5 x PW) the blank shall be removed, the gauge shall be reconnected and a pressure applied equal to the full range of the pressure gauge. The pressure is to be applied for a sufficient length of time to prove the structural integrity of the gauge fitting. 10.9 If practical, the superheater should be included in the hydraulic repeat pressure test. This requires a blank to be fitted on the outlet of the superheater. It shall be removed on completion of the test and the pipe reconnected. The regulator shall be in the ‘Open’ position for the test. For superheaters the Boiler Inspector shall assess the testing requirement on an individual basis and annotate the Written Scheme of Examination accordingly. Edited By Steambuff on 13/05/2013 18:30:51 |
David Jupp | 13/05/2013 18:58:24 |
978 forum posts 26 photos | As someone who works professionally with pressure systems, it seems to me that there is some confusion between 'leaking' and 'passing', one indicates a flaw which may become dangerous, the other is more of an inconvenience in most cases . Clause 10.9 as shown in Steambuff's post should be clear enough, passing of the regulator is not a concern - leaking may be. As for cylinders, yes they are part of the pressure system, but the probability of catastrophic failure is low, and likely consequences less severe than a rupture of the boiler or of items close coupled to it. All recent UK/EU led directives are 'risk based' - most effort / testing / inspection is concentrated where there is highest risk of harm to people ot the environment. Cylinders would have to be very large for a model to become subject to PED, boilers very easily fall within PED. |
John Billard | 14/05/2013 16:59:06 |
42 forum posts | Yes, all great stuff but the question is still not answered clearly. If a regulator has what I would call a fairly minor leak (and is quite usable in service) and the boiler is otherwise sound does that amount to a fail? Some testers are saying yes and I would say no. I guess the answer is in 10.19 and whether the pressure loss is "unacceptable" How is that word measured? Even a panel of High Court judges probably could not agree! And we arre placing that onus on our amateur testers. Best wishes John
David Jupp | 14/05/2013 18:52:01 |
978 forum posts 26 photos | Pleas calrify by 'leak' do you mean not tight between inlet and outlet, or do you mean leaking to atmosphere? If former I agree, a blank on the outlet should adequately check system integrity. If leaking to atmosphere - maybe OK from gland (though as a tester I would wonder why you couldn't be bothered to fix the gland for the test), if leaking elsewhere to atmospehere I'd say unacceptable.
Stub Mandrel | 14/05/2013 21:21:04 |
![]() 4318 forum posts 291 photos 1 articles | A cylinder failure wouldn't result in a catastrophic emptying of the boiler, the consequences would be no worse than having a drain cock open. Neil |
julian atkins | 06/06/2013 00:18:18 |
![]() 1285 forum posts 353 photos | hi john, ive made quite a few boilers and quite a few locos and lots of injectors and even made a pressure gauge but ive never yet made a loco with a regulator that didnt leak on a hydraulic test! as jopn baguley correctly observes the correct way is to blank off the regulator where it connects to the steam pipe. this also pressure tests the superheaters which is no bad thing in my book. unfortunately a lot of the published designs make blanking off the steam pipe difficult.. a bit of inginuity and forethought is often required. cheers, julian Edited By julian atkins on 06/06/2013 00:18:35 |
John Billard | 07/06/2013 18:36:37 |
42 forum posts | Thanks, Julian Yes, you are right (though I think that the screw down type is possibly more easy to make steam tight.) That is why I think that a leak at the regulator valve should be allowed within the spirit of reasonableness. To blank off the regulator on my Martin Evans Manor design would require the removal of the superheater. I do not wish to critisise the authors of the boiler code who have done a good job. It is the wide band of interpretation by testers that I think might be an issue. Kind regards John
ay dee | 21/06/2013 15:25:50 |
3 forum posts | I guess sometimes common sense is lacking - if the regulator allows too much water past to hold hydraulic pressure without pumping like mad, the inspector should fail it. Not so much because of the regulator, but because frantic pumping, water pouring out of the blast cap into the smokebox, and probably back down the tubes and out the ashpan once the smokebox fills up are not conducive to examination of leaks in the boiler. Blank off the regulator wherever you can for a hassle-free test. Not many designs allow for easy hydraulic tests, and most models need some dismantling for blanking off. |
