Riveting a cab roof
Romeo R.L08/01/2013 16:22:37
17 forum posts
Hello All,
If you look at my photos you can see that i am building a class 08 shunter, i decided to attack the cab with more detail though, adding more rivit detail. Can anyone suggest the best way of riviting in this situation? (the roof is rolled)
Should i countersink, then peen?
Or use dummy rivits like a 8ba slotless screw? (expensive i know)
i have around 100 todo on the cab piece alone (roof and sides)
Steambuff08/01/2013 16:29:57
544 forum posts
8 photos
If they are just cosmetic then I would use either Copper or Brass Rivits and soft solder them in. (From the back of course, you can also  countersink the hole and trim the rivit first if you want)
Edited By Steambuff on 08/01/2013 16:31:19
Romeo R.L08/01/2013 16:35:06
17 forum posts
Hi Dave,
Yes they are cosmetic and structural as well but solder is quite strong i guess and my struts are brass, so that might be an idea! smiley
Cheers, Romeo
KWIL08/01/2013 17:01:18
3681 forum posts
70 photos
Rather than hammering away with a snap, use a taper pin reamer to give a slight taper and then the "setting" blow will be sufficient to fill the taper and hold the rivet.Flush off on the inside.
Halton Tank08/01/2013 17:04:08
98 forum posts
56 photos
For the cosmetic rivets you can glue them using something like Loctite 601, however, if you are going to solder the the structural ones, then do the soldering first, otherwise the glued ones will fall out.
Regards Luigi
Edited By Halton Tank on 08/01/2013 17:05:04
Mark P.08/01/2013 20:26:42
634 forum posts
9 photos
No don't use loctite the rivets will fall out.Solder them in as mentioned before.
Regards Mark P.
Romeo R.L09/01/2013 09:57:30
17 forum posts
Thanks everyone, I'll work out some way of doing it, i just reckon soldering will be messy? Someone suggested to me use starlock washers (bad idea maybe?)?
