Precision Ground Flat Stock
HomeUse01/01/2013 17:44:54
168 forum posts
12 photos
I have some lengths of 50x50mm & 50x12mm which I intend to turn into rear tool post and holders - As I have never used Ground Flat Stock before, should special tools be used - tool angles etc.
Has anyone any hints or sugestions
The spec. of the steel is:-
Oil Hardening BS01 Type Alloy Steel (Its in original packaging)
Carbon 0.95% - Silicon 0.30% - Manganese 1.25% - Chromium 0.50% - Tungsten 0.%0% - Vanadiem 0.20%
Any help would be appreciated
Siddley01/01/2013 18:01:27
150 forum posts
I use it all the time and it's not awkward stuff to machine in the grand scheme of things.
It's a tough steel but 'well mannered' , doesn't seem to work harden and I don't really take any special measures apart from allowing for it's hardness.
I don't think you'll have any problems.
M0BND02/01/2013 19:42:50
81 forum posts
9 photos
Posted by Siddley on 01/01/2013 18:01:27:
Agreed, use cutting speeds of around 20 ~ 25 m/min and keep the tool and part as cool or as lubricated as you can and you will be fine.
HomeUse03/01/2013 08:58:56
168 forum posts
12 photos
Thanks - will go to w/shop and give it a go
Takeaway04/02/2013 20:28:16
108 forum posts
Hello HomeUse - Ground flat stock comes in (or used to) several different qualities which if my memory serves right could be identified by the ground finish - the coarse finish was quite forgiving but the good stuff with its finer ground finish needed to be dealt with more carefully. Machining it (tough old stuff) needs lots of coolant to prevent it work hardening but providing your tools are sharp and you keep the mistic flowing you should have no probs.The same applies to the various grades of silver steel. Please note that my advice is based on my experiences from 30 years ago - things may well have changed since then!
HomeUse05/02/2013 11:43:48
168 forum posts
12 photos
Hi Stuart - Yes I have found out that there are diferent grades (the hard way) by trial and error - and taking the edge off quite a few tools.
A local precision engineering works helped in the end by taking the ground stock from me and replacing with easy machine bright steel. - The works use it in producing pecision dies for injection moulding, but they have very specialist lathes/mills
Thanks for all coments - will stick to easy machine in future
Stub Mandrel05/02/2013 19:45:25
4318 forum posts
291 photos
Hi HU
I hope you got a good exchange rate!
HomeUse06/02/2013 09:28:30
168 forum posts
12 photos
Yes Neil - 2.5 times weight of Ground in BMSteel - I think that is fair MikeB
John McNamara06/02/2013 13:25:13
1377 forum posts
133 photos
Hi Home Use.
Not all ground stock is Flat .... I was given a nice bundle by an engineering friend still in the wax paper. both British and US stock. It may be ground but that doees not mean it is truly flat, bows of a few thou are evident in many of the pieces Mostly new 18 ingth lengths. I have found it is fairly easy to mill and yes with coolant.
Worth bearing in mind if you plan to use it as is...
Cheers
John McNamara.
