James Newbould | 31/12/2012 14:19:51 |
3 forum posts 4 photos | Hello I wonder if somebody might be able to help me identify this traction engine. It belonged to my grandfather and I have just been given it as a present. The problem is (A) I don't know what engine it is and need to get a part for it. (B) I need to know how to steam it. I think it runs on paraffin but don't have any idea how to do this. Any help appreciated James
James Newbould | 02/01/2013 17:57:41 |
3 forum posts 4 photos | |
Jeff Dayman | 02/01/2013 22:56:12 |
2356 forum posts 47 photos | Could you take some more photos of the firedoor / firebox areas please? The underside of the boiler and firebox and tender areas too. If the smokebox opens, please take a photo inside it (use a flashlight if needed for extra light. Extra detail is needed to make any comment about method of firing etc, What part do you think you need? What safety valves does the model have? Safety valves and the boiler need a careful check before trying any sort of fire in the model, for your own safety. What is the max pressure noted on the pressure gauge? What are the diameters of the wheels and the overall length? JD Edited By Jeff Dayman on 02/01/2013 22:56:35 |
Philip Rowe | 03/01/2013 00:12:56 |
248 forum posts 33 photos | H James, Can't be sure from the photo, but it looks very much like the 3/4" scale Burrell type traction engine as sold by Bassett-Lowke. The gear train is a little unusual to my mind and is identical to the catalogue photo. The boiler is listed as being copper, water tube type, spirit fired. I have a copy of their model catalogue circa 1958-60 where this is listed as a finished model complete with instructions and accessories for running priced at £136. Castings and materials are also listed with eye watering prices, for example cylinder set priced 8s 6d (42 1/2p). Seems silly money to us nowadays but then what was the average wage then? I'm sure it will be in proportion. Phil |
JasonB | 03/01/2013 08:35:32 |
![]() 25215 forum posts 3105 photos 1 articles | Here is a better example And an even better one
James Newbould | 03/01/2013 08:57:04 |
3 forum posts 4 photos | I will try and get some better photo's later. |
Stub Mandrel | 03/01/2013 20:44:36 |
![]() 4318 forum posts 291 photos 1 articles | Hi James, Looks like you have something rather special there. A copper boiler should still be safe to steam, if it passes a pressure test. Neil |
Jeff Dayman | 03/01/2013 20:56:54 |
2356 forum posts 47 photos | I think Jason nailed it - it certainly looks like Bassett Lowke's. What part or parts do you think are missing? |
