Ml7 apron handwheel
michele bresciani23/11/2012 13:36:37
5 forum posts
Hi guys. I need helpi've just bought a Myford Ml7 and i have a little problem: the apron handwheel has bit of play, what can i do?
https://www.youtube.com/watch?v=Kyed68qGwOI&feature=youtube_gdata_player
Check out the link, ive posted a video on you tube
Thank you so much
Michele
Bazyle23/11/2012 17:37:25
6956 forum posts
229 photos
not sure from video but is it wobbling on the shaft ? as opposed to just having a bit of back lash?
michele bresciani23/11/2012 19:36:31
5 forum posts
I think there's a clearance between the rack and pinion..is it possible to fix it? Maybe with a new pinion
Grizzly bear23/11/2012 21:15:39
337 forum posts
8 photos
Hi Michele, Welcome to the forum.
As an ML7 owner myself, I'm sure Graham has identified your problem. Are you into model making?
Regards Bear..
Gordon A23/11/2012 21:40:51
157 forum posts
4 photos
Hi Michele,
I had a problem with worn ML7 apron bushes and bought a replacement set from here.
http://www.lathespares.co.uk/
Gordon.
michele bresciani24/11/2012 12:31:44
5 forum posts
Thank you so much guys, i've just bought a replacement set of apron bushes..hope it works..Grizzly, no i'm not really in model making, i'm into pipemaking
Grizzly bear24/11/2012 13:36:13
337 forum posts
8 photos
Pipes, would they be Pan Pipes or Smoking Pipes? Bears can be a bit nosey.
Regards Bear..
michele bresciani24/11/2012 13:49:58
5 forum posts
Uilleann pipes, the irish bagpipes. Have you ever seen them?
Michele
John Stevenson24/11/2012 13:57:42
5068 forum posts
Irish pipes ~?
Are they similar to Guiness bottles that have open other end on the base but in this case it's blow from tother end ? wink
Grizzly bear24/11/2012 14:24:04
337 forum posts
8 photos
Uilleann pipes, Interesting. Had a look on Youtube. This bear is not musical.
What will the main material be, just wondering if a wood turning lathe would have been a better option.
Regards Bear..
michele bresciani24/11/2012 14:32:40
5 forum posts
The main material will be ebony. i bought a metal lathe so i can turn out reamers an the whole metal parts
