ML7 spindle questions
Jolyon de Fossard07/11/2012 21:45:02
15 forum posts
Hello all,
A couple more questions about my ML7 rebuild if I may; firstly, what should I use to lubricate the thrust bearing and secondly, I notice quite a lot of initial resistance to movement in the reassembled spindle. The bearings are back in the same places and the same way around; the shims are in place and the spindle is clean. There are no tight spots and taking it apart again I see no signs of metal to metal contact so I am assuming it's just the viscosity of the oil causing drag. Are there any more checks or tests I can do ?
Yrs,
Jolly
_Paul_08/11/2012 09:45:13
543 forum posts
31 photos
Hi Jolly,
I use ISO32 oil (Esso Nuto).
I took my ML7 spindle out to replace the backgear & drivebelt when I put it back together it did seem a little stiff initially I took it apart again to make sure everything was OK and it was so I ran it for a while checking for any undue heat and it soon loosened back up again.
Subsequent examination of the bearings shows no problems.
Paul
Edited By _Paul_ on 08/11/2012 09:45:36
Dan The Man11/12/2012 22:53:21
10 photos
Spindle 9
Hi Jolly,
I stripped this ML7 down as there was slippage between the brass gear and the aluminium pulleys.
The main key is - ABSOLOUTLY CLEAN.
Mine also was a little tight on startup, backed off the nut for the thrust bearing and re-set then all ok.
Unlike ball races though these bearings can have slight tendency to resist initial movement.
Dan
Edited By David Clark 1 on 12/12/2012 08:42:58
