Here is a list of all the postings Jolyon de Fossard has made in our forums. Click on a thread name to jump to the thread.
Thread: Aerospece grade aluminium tubing |
12/06/2018 16:46:02 |
Thank you all for your considered response. The tonearm is quite rare and was an expensive item in its day. I would like to keep it looking original as much as I can so am not attracted to carbon fibre superior as it may well be in this application The original was Nickel plated which is a strange choice really so I will be anodising the whole thing as later versions of this arm were. So; I suppose I'll just use a nice looking tube from B and Q. I enjoyed the comparison with a Myford restoration. As it happens I rebuilt my 1948 ML7 and used original paint but I ditched the motor and added a 3 phase machine with an inverter drive. So, it is a blend of old and new. Yrs Jolly |
12/06/2018 11:57:13 |
It is not for an Aerospace application but I am happy to pay for Aerospace grade material unless the feel is that the material isn't appreciably better in terms of the attributes I am looking for.
11/06/2018 13:19:22 |
Thank you everyone. The application is not safety critical. I am rebuilding an old high quality tonearm from a 1960's hifi record player. The original tube was damaged. I don't know what it was but assumed it would be something more than the standard architectural grade. But, the tube I bought in B and Q will do. I was wondering if it wouldn't be too hard to find something better. Yrs,
Jolyon |
10/06/2018 20:40:58 |
Hi everyone, I have am looking for some aerospace grade aluminium tubing. The property I'm looking for is a good stiffness/resistance to bending to mass ratio. Don't care about weldability or machinability as I have to do relatively little to it in reality. The grades that that I think are suitable are 6061 or 7075 I need a 10mm diameter tube with a 1mm wall thickness and I need about a metre of it. Please can someone advise me of a place where I can buy more specialist grades of aluminium tubes such as these.
I am in the UK.
Yrs,
Jolly |
Thread: ML7 spindle questions |
07/11/2012 21:45:02 |
Hello all,
A couple more questions about my ML7 rebuild if I may; firstly, what should I use to lubricate the thrust bearing and secondly, I notice quite a lot of initial resistance to movement in the reassembled spindle. The bearings are back in the same places and the same way around; the shims are in place and the spindle is clean. There are no tight spots and taking it apart again I see no signs of metal to metal contact so I am assuming it's just the viscosity of the oil causing drag. Are there any more checks or tests I can do ?
Yrs,
Jolly |
Thread: Myford ML7 safe spindle speed |
17/10/2012 22:54:44 |
Fantastic news ! Thank you. I have an inverter on my Colchester Student so will probably install one on the Myford as opposed to tracking down a Tri-Leva and a two speed motor. The Tri-Leva does look nice though.
Jolly |
17/10/2012 22:04:17 |
Hi Terry, Do you run your ML7 at that speed occasionally ?
Yours,
Jolly |
16/10/2012 23:23:53 |
I saw this on Tony's wonderful site lathes.co.uk http://www.lathes.co.uk/myfordtrileva/img8.jpg It shows a speed of 1280 rpm is possible for the ML7. Yrs,
Jolly
16/10/2012 08:22:17 |
HI,
I have to say that I am thrilled with the lathe. Now it's been taken apart I can see that it is in lovely condition mechanically. I learned to turn on my Dad's ML10 (he's a clockmaker by profession) so having a Myford in my workshop is quite something. Also, compared with Colchester, spares seem cheap ! Apart from the aforementioned bits and pieces I'll I'll need is an MT2 dill chuck, live centre and a Dickson tooolpost then I'll be a way. Oh yes, and I'll have to make a bench for it. As an aside, where can I buy QWhite Metal for making bearings ? Yrs,
Jolly.
Thread: Colchester Student owner's question |
15/10/2012 21:59:13 |
Did you ever find this out ? If not; let me know and I'll nip off to the workshop with my calipers.
Yrs,
Jolly |
15/10/2012 20:31:09 |
Hi Chaps,
Thank you all for your very helpful comments. It looks like I shouldn't worry about this but wanted to hear the experience of others before I went ahead. Currently, the lathe has small metal oilers. I'll replace these with the tall glass ones so I can see the oil level and and adjust the flow. Kind regards,
Jolyon |
15/10/2012 17:53:41 |
I could make some Bronze (NAB I assume) bushes on my Colchester and maybe get the spindle Nitrided or would Nitriding require grinding afterwards ?
Yrs,
Jolly |
15/10/2012 16:12:46 |
Thank you both. I'll make a motor pulley that'll get me to 1070 rpm and use Castrol Hyspin 32 maybe with some Molyslip in and I'll take care ! Yours,
Jolly Edited By Jolyon de Fossard on 15/10/2012 16:13:27 |
15/10/2012 15:30:32 |
Hi, I'm in Bath, UK. The Student's fine and I'm very happy with it; I just think that it's a bit over the top sometimes using a 3 HP machine to work on things 10mm dia and smaller. Very pleased with its ability to turn some steel into a pile of swarf and I can work to a thou on it so it's still accurate enough. I just wanted something smaller and this ML7 was given to me so I'm determined to get it running but was surprised that it can't spin as fast as the Student. I make parts for turntables (record players) and sell them on-line. I'm an electrician by trade but it's not as much fun as a day in the workshop with my machine tools, a teapot and the radio. Yours,
Jolly |
15/10/2012 09:05:55 |
Hi, I'm new here and am seeking some advice, please. I have just got a 1969 Myford ML7 which I am restoring. My main lathe is a Colchester Student which is great but a little big for some of the work I do. I read, however, that the ML7 maximum spindle speed is about 600rpm (Colchester runs to 1200). My L7 has White metal bearings. I was wondering whether modern lubricants have enabled forum members to increase the spindle speed safely and if so, by how much ? If not; could I add a Super 7 headstock or whuld that necessitate changing backgear/countershaft etc. Apart from eBay can anyone recommend a place for Myford spares ? I need a few other things like a rack, some oilers and a leadscrew hand wheel.
Yours with thanks,
Jolyon |
