Myford ML7 Dividing head attachment
What kind of Arbor to use
Robin teslar28/10/2012 01:22:55
127 forum posts
8 photos
Hi Myford people
Ive just acquired the above Myford dividng head, what precision! But I am puzzled as to what arbor attachment to use. Ive searched around Myford with no obvious answer. The head has two fixed centres and is obvious intended to use a between-centres arbor with spacing collars and clamping nut. But the nose is the usual 1 1/8 12 tpi Myford to fit a Myford chuck which could then clamp the arbor, but there is not much room and photos Ive seen show a 3ins backplate and maybe a carrier, but I cant find this offer for sale anywhere? So maybe Im barking up the wrong tree. Anyone know how it is done?
Cheers
Robin
RobC30/10/2012 09:20:32
54 forum posts
Hi Robin,
I have used mine a few times now and although it came with a small chuck mounted on the 'nose', I used my ER32 Collet Chuck instead to hold my arbor. This works nicely as there is less overhang with the smaller chuck diameter and also less weight on the mechanism in general.
I will see if I can dig out any photos of the setup. I am sure I have some, as I was pretty chuffed when I managed to get it all setup and cut a gear for the first time.img_1100.jpg
Alternatively, I have seen the dividing head mounted up to the left of the headstock, so that it can be used to index the spinlde round for operations that you control on the cross slide, but I have not yet found a suitable way to attach and hold it round there.
Cheers,
Rob
Edited By RobC on 30/10/2012 09:33:24
Bazyle30/10/2012 09:55:15
6956 forum posts
229 photos
I think the idea is use either the chuck alone or between centers, not chuck to center. Between centers the carrier is just a standard one and a drive plate is just a chuck backplate.
However as the drive plate does not need any precision like a chuck you can turn it up yourself even if a beginner to screwcutting and it can be aluminium. It makes sense to fit a brass locking screw. For small workpieces with little stress you don't even need to make it threaded - just a close fit over the thread and hold with locking screw. Finally for a quick hack just use a jubilee clip.
KWIL30/10/2012 10:09:30
3681 forum posts
70 photos
Myford illustrations show clearly between centre on overarm and with the arbour retained in a collet Nose is standard with 2MT, so you can choose, ER adaptor, 2MT arbour, Myford collet whatever you like.
Bazyle, this is a precision dividing head, properly fitted drive arrangements lead to better concentric accuracy!
Robin teslar30/10/2012 10:44:45
127 forum posts
8 photos
Hi all
I though I was being thick, but it seems to me that Myford stopped developing the Diving head and so never made a milling arbor kit to suit, they don't even suggest what to do. I will opt for the between centres arbor and backplate system. Collets (er25 adaptor £100, collects £145) is a bit steep for me.
Ive never cut a gear this way before, but ive hobbed a few in my time.
PS Rob
How do you find the Trileva shown in your photo?
Cheers keep turning
Robin
KWIL30/10/2012 10:57:02
3681 forum posts
70 photos
Rob, you can make an attachment that enable use on the otherside of the headstock. You need a 2MT arbour with short drawbar and with a split collar to pick on the left hand end of the spindle (I always use it on my Myford S7, it has a nice ground surface here). An adaptor plate with a round bar picks up the overarm hole and at the other end of the plate I have a hole with aligns with the arbour of part of the gear train.
Look at Pic 6 in my album which shows it this way, albeit it is not very well displayed.
Robin teslar30/10/2012 13:28:23
127 forum posts
8 photos
Hi Kwil, great album, though I struggle to understand some of the smart things you are doing just from the photos. Presumably you have posted description of what you are doing elsewhere on the board but I cant access them?
Perhaps you could post some links
I dont quite follow what you have done with the Myford divider on pix 6?
Cheers
Robin
KWIL30/10/2012 14:31:41
3681 forum posts
70 photos
Rob,
See your PM box.
The Dividing Head is mounted on the left hand end of the spindle. The chuck holds a new toolslide base for a Toolslide which holds a DRO scale inside. (see pic 7).
I do not normally post descriptions in a Forum Thread which relate to a picture, but merely use the photos to explain something. Early photos in the album explain the inside pads etc for a boiler for Locomotion for example.
K
RobC30/10/2012 15:42:14
54 forum posts
Thanks for the description, Kwil, but I think I need a photo to visualise it properly. I think I get the jist of it, however.
Robin, the Tri-Leva is fantastic, but I don't fancy trying to fix it if it goes wrong! It makes the whole user experience so simple. Once I can work out how to engage the back gears, I should be good.
Rob
Bazyle30/10/2012 19:14:03
6956 forum posts
229 photos
Back to the start of the thread. When this dividing head was launched Myfords were sold with the motor as an extra let alone a chuck. Only industrial users would be expected to buy a dividing head and they would have no trouble making the arbours etc so the market for accessories was minimal.
Cornish Jack30/10/2012 21:02:40
1228 forum posts
172 photos
RobC - the TriLeva is an excellent device, even more so when coupled to a VFD 3 phase motor. Probably with that configuration you could dispense with the back gear.
One point to bear in mind - if you ever need to fit a new belt, you really ought to do all three at the same time - the hassle getting one fitted is a bit of a pain so do them all while it's in pieces!!
Rgds
Bill
Robin teslar30/10/2012 21:32:43
127 forum posts
8 photos
Hi all
I came across this site relating to speed controlled motors on Warco
I infer that a vfm shouldnt be regarded as a replacement for a back gear. Trying to do heavy slow work would likely overheat the motor. This site advocates the use of a computer fan to assist cooling. Sounds like a smart move for a few quid.
Ive got todo some homework on vfm and stepper motors and their controllers. I only ever did traditional motors at college many years ago. Anyone remeber the Ward Leonard system?
I think a trileva kit went on ebay recently for about £300
Cheers, keep turning
Robin
KWIL30/10/2012 22:51:09
3681 forum posts
70 photos
Definately remember Ward Leonard systems? Yes and other  motor generator combinations.
Of course. I certainly use VFD drives on my machines and at low speeds, however there are limits, time at such low levels needs to be watched, a hand on the motor from time to time can be useful. I screw cut at 200rpm, but do not expect to take really heavy cuts at such speeds when in a high speed pulley setup but with the VFD turned down. One needs to be sensible about load.
Edited By KWIL on 30/10/2012 22:52:12
