Optical Instruments - Terminology?
Swarf, Mostly!17/10/2012 15:14:11
753 forum posts
80 photos
Hi there, all,
I hope that my question won't be ruled as outside the scope (no pun intended!) of this site - I know that at least one member will have the answer.
On that well-known auction site there are often listings for engineer's (maybe it would be better to say 'surveyors' ) levels, the tripod-mounted telescope with a bubble and a cross-hair reticle.
They are often described as 'Dumpy' levels but I thought that was a trade name, not a generic one. Am I mistaken?
They are also sometimes (often!) described as 'theodolites' which used to annoy me but nowadays I just shrug and move on.
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 17/10/2012 15:15:03
Martin Kyte17/10/2012 15:28:27
3445 forum posts
62 photos
I am happy to bow to superior notice but I believe the Dumpy bit indicates that the instrument auto levels itself when set close to level. It does this by use of a compensating thin prism which is suspended by its upper edge. Small errors in setting the instument level on the tripod are compensated for by the attitude of the prism.
regards Martin
David Littlewood17/10/2012 15:41:46
533 forum posts
Google is your friend.... **LINK** and **LINK**
David
Clive Hartland17/10/2012 17:06:10
2929 forum posts
41 photos
A Dumpy Level is a level that has a bubble in tandem with the telescope,and when levelled over the three footscrews will determine a back to back level around a project. It usually has a circular bubble that allows coarse levelling of the instrument before critical levelling of the tubular bubble.
It is used in conjunction with a surveyors stave and needs two operatives. Accuracy will be about 2.5mm at a 100mtrs.
An Automatic level is quite a sophisticated Level, it has a damped pendulum that has about 15' of swing back to front and sometimes has a flag comes into view to show it is out of level. Again it has a circular bubble of 20" accuracy for course levelling for setting up.
These levels nominally are about 8" accuracy and some less than 1" and to 100ths with an attached plan Plate over the OG. EG. An N3(70) from Leica.
Theodolites are now being designed and built with so many functions that we workers who repair them have a job to keep up with the technology. The latest is fitted with a TV camera that allows realtime viewing of the target and has X hairs in the pic.
Laser measuring is now the Norm with reflectorless working and accuracy to sub 1mm.
Most are now automatic and can seek out a special target, the Theodolite is left in one position and the operator walks about with the target on a pole that also determines the height of the ground at that point. As stated variations exist with GPS which is used for larger surveys and you may see them used by Police at road accidents also.
