ntambomvu | 14/09/2012 17:27:37 |
4 forum posts | Does anyone have information about the use of linear bearings as the beds in homemade lathes and milling machines??
Michael Gilligan | 17/09/2012 21:17:15 |
![]() 23121 forum posts 1360 photos | Welcome aboard, ntambomvu Not specifically ... but they do work very nicely on microscope stages and such. The steady load capacity can be astonishingly high, but I suspect you may have problems [bearing tracks pitting] caused by vibrations that are transmitted from the cutter. It really depends what sort of work you are expecting the machine to do. ... A heavily built machine, taking light cuts, could be fine. What do you have in mind? MichaelG. Edited By Michael Gilligan on 17/09/2012 21:51:34 |
John Stevenson | 17/09/2012 21:29:48 |
![]() 5068 forum posts 3 photos | Most commercial machines now use linear bearings for the bed ways instead of slides. |
ntambomvu | 18/09/2012 08:44:07 |
4 forum posts | Hello Micheal- nice to meet you I recently bought a cheap bench lathe and have fitted it with servos and am running mach3 There have been many problems. Fitting limit switches,fitting home switches making fittings for the ball screw - routing wiring away from interference ( mechanical and electric) ts. Other issues are that the gearbox is noisy and the speed range is inadequate. So instead of messing around with something of known dubious quality- I am going to convert it back to original and rather build myself a new all electronic lathe. I am sure it will probably be cheaper ( and better) than trying to work with something junky and badly made. ( one of the things that I had to do was to strip down the gearbox completely and take about a teaspoonful of foundry sand our that had been left there. regarrdes fred |
Michael Gilligan | 18/09/2012 09:22:36 |
![]() 23121 forum posts 1360 photos | Fred ... that's much easier name. O.K. that sounds like a good plan. It would be worth looking at the components available from Marchant Dice. [they also trade on ebay, so you might find a bargain] Provided that you keep a realistic balance between the "weight" of the machine, and the loads you expect to put on it; the only real problem will keeping the dust and swarf out of the linear bearings. Good luck ... and please keep us informed of progress. MichaelG. |
