David Hughes 3 | 07/09/2012 23:01:25 |
8 forum posts | Would anybody know the correct level/weight of grease in the 2 speed g/box of a VM30, not sure if the level that was in it was correct. |
KWIL | 19/09/2012 09:48:33 |
3681 forum posts 70 photos | According to the Boxford original instructions the gearbox was filled with BP Energrease F600-EP at works and did not need further attention. When I cleaned and refilled my gearbox I used Castrol Semi Liquid Grease, Castrol Spherol - EPO Grease, as I recall around 20 fl. oz, enough to cover the gears at the base of the gearbox. |
David Hughes 3 | 20/09/2012 01:04:16 |
8 forum posts | Thanks for the info,much appreciated, had found an alternative grease but was unsure of the level/weight, as like you I needed to replenish the grease. |
