Oscillating Spindle Sanders
How do they work ?
Michael Gilligan13/08/2012 06:27:35
23121 forum posts
1360 photos
Can someone please tell me how the Oscillating mechanism in a vertical axis Spindle Sander works ? < Example >
... is it some sort of Swash-Plate arrangement ?
I have a useful-looking motor, removed from a Garden Shredder. enlightened
Thanks
Here is one answer
Edited By Michael Gilligan on 13/08/2012 06:40:09
Martin W13/08/2012 10:25:36
940 forum posts
30 photos
Michael
Just had a quick look at the exploded diagram in the manual you linked to. The reciprocating drive for the spindle is, I think, fairly straightforward (if I am correct that is wink 2  ) and is derived by use of a worm gear on the motor shaft driving a reciprocating crank which moves a keyed sleeved up and down on the motor shaft to which the sanding drum is connected.
I more detail;
The motor shaft has a worm gear (15) fitted which drives gear (30), this gear is fixed on shaft (35) which drives the connecting spindle (28) via the connecting rod (18). This reciprocating motion is coupled to the spindle seat (22) which houses the spindle (60) and couples to the sanding drum . The drive from the motor to the spindle is made by use of a long key (12) held by a set screw (13) over which the spindle seat (22) and spindle are free to slide, a fairly crude spline.
The only thing which is not clear from the diagram is the coupling of the reciprocating motion to the spindle seat. This could easily be acieved using a couple of links coupled between the connecting rod ends and the spindle seat.
Cheers
Martin
Edited By Martin W on 13/08/2012 10:29:39
Edited By Martin W on 13/08/2012 10:37:15
Edited By Martin W on 13/08/2012 10:42:23
Michael Gilligan13/08/2012 13:19:53
23121 forum posts
1360 photos
Martin,
Thanks for the very useful reply.
I must confess, I hadn't really looked at that manual when I made my original posting. ... I just linked to it instead of the catalogue picture.   [06:27 is a bit early in the morning for me these days]
Edited By Michael Gilligan on 13/08/2012 13:22:24
