Wolfie | 09/08/2012 23:41:02 |
![]() 502 forum posts | Calling folk that have made the HH grinding rest.
I've made a mistake on a part. Part 4, lower slide. In the book some of the dimensions are sideways on, in other words you have to turn the book or your head to read them. |
dcosta | 10/08/2012 01:20:43 |
496 forum posts 207 photos |
Hello Wolfie.
Wolfie | 10/08/2012 06:54:52 |
![]() 502 forum posts | What would I need to do to part 16?? Is it not just 15 I need to consider? I already noted the 15mm depth of the oval slot. As for the other mods, I have already made most of the locking handles but I also constructed it with the thinner side arms as per the revised plan. |
dcosta | 10/08/2012 12:09:04 |
Hello Wolfie.
Ziggar | 10/08/2012 17:32:25 |
![]() 115 forum posts 1 photos | Hey Wolfie
i also made the grinder rest from Harolds book, followed it to the letter and all worked fine as it should do and as was expected. others have made it and made it out of sequence and run into trouble with locking mechanisms not fitting or getting in the way and such like but if they had simply followed the book then it would have been all OK i think i made the same mistake as you though and also buggered up the slot in that piece too
so i -did- start that piece again, and was happy that i did just follow the plan and instructions. no need to modify anything to get it to work. it works just fine and does exactly what you think it will do
make the piece again, you know its the right thing to do
Edited By Ziggar on 10/08/2012 17:33:59 |
