Anyone got a list of Elmers abbreviations ?
Chris machin18/05/2012 13:08:22
59 forum posts
Hi all , As per thread title has anyone got a list of the abbreviations used on Elmer Verburgs engine plans ? I am having a go at no 24 Beam engine and there are letters such as c,s,b on the drawings , what do they mean
Any help much appreciated
Thanks
Chris.
JasonB18/05/2012 15:26:52
Its available on line but there are some issues with copyright so I have PM'd you the link.
J
Jeff Dayman18/05/2012 16:26:42
2356 forum posts
47 photos
I replied to the "elmer's engines" thread a while ago with the note below:
C - close fit
S - smooth finish
P - press fit (or Pray it fits) - sometimes PF also used
SF - slip fit
LF - loose fit
B - braze or silver solder
F - make flat
SWT - seal watertight
SGT - seal gas tight
W - weld
H- harden
H&G - harden and grind
These conventions were and are used on some North American tooling drawings as guides for skilled toolmakers. Many old timers I worked with would see specified tolerances on tool drawings as an insult to their skills in making and fitting a machine to work as expected, and preferred to see the notations above used rather than tolerances.
www.john-tom.com has free PDF files of plans for several of Elmer Verburg's engines.
When I used to work for a large USA based controls company in their tool design office we came up with several unofficial variations on the above symbols over the years, as below:
RF - rust fit -as in when a steel shaft is turned too small, leave it outdoors for a week, then the rust coating will allow it to fit right
PH - not just a press fit, Pound Hell out of it.
LAMW - loctite, after machining it wrong
GIRD - get it right dummy (it's important) as applied to an important dimension
WWD - weld without distortion (ie perform distortion control measures) but this was interpreted as "weld when drunk" a few times.
Have fun with the Tiny. Elmer's engines are great.
JD
David Littlewood18/05/2012 17:51:40
533 forum posts
Jeff,
ROFL! Your "rust fit" reminds me of the practice, in the early days of railways, of fixing wheel to axles by packing the rather loose joint with iron filings and urinating on it. As you say, after a week it was as tight as needed (one hopes!).
David
