Hand pump
Deltic00712/05/2012 20:19:27
131 forum posts
12 photos
Hi all,
Can anyone help me.
I am looking to make a tender type hand pump,does anyone know where I can get hold of drawings,not bothered about bore size as I can change to suit.
thanks in advance
Deltic 007
Ian Fowkes13/05/2012 10:35:12
31 forum posts
You are welcome to use this design of mine, no dimensions are shown but the basics are bore10mm or 3/8", stroke 32mm, ball dia 6mm or 1/4", ball seat bore 5mm, ball travel limited to 1mm by 1.5mm dia pin through body. Pump body 16mm or 5/8" dia, valve box 12mm or 1/2" dia, valve box fittings from 12mm or 1/2" hex. Eveything else can be measured from the drawing and scaled to suit your particular requirement. The main body is designed to be fabricated from whatever non-ferrous materials are available by silver soldering (Before machining) or the dimensions could be modifed to suit a casting if available. There is no O ring or gland but if required an O ring could easily be fitted in a groove turned in the ram.
Cheers Deltic.
Ian.
Handpump
Deltic00713/05/2012 20:53:37
131 forum posts
12 photos
Thanks just what i was after.
Deltic
Deltic00713/05/2012 20:53:43
131 forum posts
12 photos
Deltic
