Ian Welford | 07/04/2012 23:11:43 |
300 forum posts | Having been asked to make a "flute tuner", or rather repair a borken one by a friend. I needed to attach a cork plug to one end of it. The tuner is ( I suspect) rosewood and about 40 years old! I used "mopane" from Zimbabwe as the grain match is good. Then, being masochistic, decided to make a duplicate in African Blackwood. All fine until came to attach the cork to it. In the end I;ve used Araldite ( slow setting as I know I can rely on it). The original looks like it may have a pin or stiff rod through it's centre to reinforce the cork. Anyone found any better adhesives for cork? Didn't want to use contact adhesive as It MUST be central on the base and it took quite a while to get the diameters right. Ian I will try and put photo's up tomorrow. |
_Paul_ | 08/04/2012 01:31:48 |
![]() 543 forum posts 31 photos | In my youth I used to re-line British motorcycle clutch friction plates with cork which I stuck on with Araldite (only the original version available then). Wonder if you can still get the thin sheets of cork? my old Kawasaki needs a new clutch and I dont fancy the £30-40 for a set of friction plates...... Regards
Paul
John Haine | 08/04/2012 08:44:24 |
5563 forum posts 322 photos | Cork tile adhesive? |
