RICHARD GREEN 2 | 28/03/2012 12:40:23 |
329 forum posts 193 photos | Last December I bought a TOS FA3A universal mill, and this casting was included with the machine, and is painted the same colour, has anyone any idea what it is, the TOS factory dosen't recognise it as part of the mill, With the swivelling head of the mill in the horizontal position it could make a very useful end support for a long boring bar, with the dovetail end somehow fitted to the mill table, Has anyone got any ideas ? Richard.
Baldric | 28/03/2012 12:53:49 |
195 forum posts 32 photos | It looks like the support from a shaper, these add additional support to the table, see here and here |
RICHARD GREEN 2 | 28/03/2012 13:04:07 |
329 forum posts 193 photos | Hello Baldric, Yes you could be right, What confused me was that it's painted exactly the same colour as the TOS mill , and the paint looks original, as it does on the mill.
Richard. |
David Clark 1 | 28/03/2012 13:10:02 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
The bottom dovetail clamps to the the cross slide dovetails of the mill, the slots are to bolt to the overarms. Each overarm will be tapped for a bolt in the middle of the round bar. It steadies the mill up when taking heavy cuts. Similar one here but does not use the dovetail. You can slide the attachment closer to the body of the mill by moving the overarms closer to the mill. You set the height of the mill then tighten the two bolts to the overarm. Makes the mill far more rigid. If it does not do this, it is off a different mill. regards david
Edited By David Clark 1 on 28/03/2012 13:14:03 |
Baldric | 28/03/2012 13:11:56 |
195 forum posts 32 photos | Looking again not sure why it would have a dovetail on the bottom though unless is was modified for use on your mill. |
RICHARD GREEN 2 | 28/03/2012 14:16:21 |
329 forum posts 193 photos | David, The TOS mill hasn't got dovetails on the "y" axis, it's got rectangular slideways, so this casting won't fit on there as an overarm support, but I see what you mean.
Richard. |
Mike Poole | 28/03/2012 14:18:44 |
![]() 3676 forum posts 82 photos | does the mill have a dovetail overarm? maybe it fits the other way up. Mike
RICHARD GREEN 2 | 28/03/2012 14:26:08 |
329 forum posts 193 photos | Hello Mike, Yes the mill has dovetails on the overarm but they are 2" narrower than those on the white casting, so it dosen't look like they fit there, I think I might have to accept the fact that it came from another machine, Richard. |
RICHARD GREEN 2 | 28/03/2012 14:38:01 |
329 forum posts 193 photos | Here is a picture of the TOS Mill, |
mick | 28/03/2012 16:47:43 |
421 forum posts 49 photos | I think you've got a piece of another machine, did you buy it at factory clearance? It does look very much like a shaper table support. |
RICHARD GREEN 2 | 28/03/2012 16:51:09 |
329 forum posts 193 photos | Hello Mick, I bought the mill from a dealer, and the casting came with it, But I agree with you, it looks like it came from another machine, Richard. |
Bazyle | 28/03/2012 17:28:11 |
![]() 6956 forum posts 229 photos | one of the pictures here http://www.machinestock.com/site/Milling-Machine---Vertical_TOS_FA-3A---H_1053-002885_uk.html shows a different pair of support bars on the table. They might fit together in line as per one of the pictures David linked. See if you can find ways that that design could be used on your machine then go back to your supplier and demand the right ones. They probably have another customer who would really appreciate having the right item. Nice mill - looks like a true Universal with rotating table? |
RICHARD GREEN 2 | 28/03/2012 17:43:42 |
329 forum posts 193 photos | Hello Bazyle, Yes it is a true universal mill, the table swivels 45 degrees either way, the dealer didn't have any other parts for it, I have another TOS FA3A mill, only its the horizontal version, with no overarm supports !, I bought this universal mill for the swivelling vertical head, which is now on the horizontal mill, The horizontal mill has slightly more travel in the "Y" direction, which is what I needed at the time, Also the horizontal mill has done almost no work, even though it was made in 1976, With a 54" x 12" table, power feeds and rapids all ways it's a very useful machine, I'm building a 6" Burrell traction engine so some parts are quite heavy, this TOS mill is ideal for what I'm doing. Richard. |
Speedy Builder5 | 28/03/2012 18:02:03 |
2878 forum posts 248 photos | This reminded me of a friend of mine. Whilst he was finishing his final year as an apprentice, the factory went bust, but to get his certificate, he worked the last couple of months (Cash in hand) stripping various machines and exporting them. On the last few machines, there were lots of bits 'spare' and as the shop floor had to be cleared, they went on the inventory as "odding bars" Which translated was any sodding bars left. I think that perhaps my friend's son packed your mill up for you. |
mgnbuk | 28/03/2012 19:07:20 |
1394 forum posts 103 photos | There are two tapped holes at the end of the Y axis shears on the front of the knee - I am pretty certain I have seen this type of machine fitted with a brace like that from the overarm to the knee to minimise deflection (of knee or overarm) under heavy cutting conditions. The large slot would appear to be to clear the Y axis screw boss. I would expect the overarm to be brough further foward than it is shown in the picture, with the bracket fitted to the overarm dovetail - the large slot passing over the Y axis screw boss & secured to the knee via bolts into the two tapped holes. £0.02 Nigel B. |
RICHARD GREEN 2 | 29/03/2012 08:48:28 |
329 forum posts 193 photos | Nigel, The dovetails on the bracket don't match the dovetails on the overarm, and the two holes on the knee don't match the two slots on the bracket,
Richard. |
