Please identify this milling clamp
MAC03/03/2012 23:14:15
68 forum posts
Hello all.
The pictured item came with my milling machine. It's obviously a quick release clamp of some form, just wondering what they would usually be used for. Repetitive work? The travel of the moving jaw is about 2mm.
And what would it be called?
Many thanks.
Edited By MAC on 03/03/2012 23:19:35
Martin W04/03/2012 00:09:21
940 forum posts
30 photos
Mac
From your pictures it looks as if the clamping face is held against a central thrust point by a spring at either end. If so then when the clamp is tightened up the clamping face can move to accommodate any small misalignments. My guess is that it is a low level clamp with a gripping face that can adjust to a slightly out of true face of a piece of work that is supported against some fixed clamps on the table.
Well thats my guess and I wait to be corrected by the more knowledgible members of this forum.
Martin
MAC04/03/2012 00:16:14
68 forum posts
Hi Martin - yes, that's my opinion too. The clamp would adjust to a slight angle.
Would just like to know what it would be typically used for - as I can't think of anything.
Mike.
Bazyle04/03/2012 00:33:45
6956 forum posts
229 photos
Quick clamps are often used for holding items for engraving.
Ed Duffner04/03/2012 03:44:40
863 forum posts
104 photos
It's a bit like the Hold and Fold clamps used for bending the brass etching made for plastic model kits.
Hold and Fold
Edited By Ed Duffner on 04/03/2012 03:45:17
frank brown04/03/2012 06:46:45
436 forum posts
5 photos
Mac, imagine you have to reduce 1000, three inch lengths of 1/4" bar to, say .200" on your milling machine. set a thin stop on one side use this beast on the otherside and you are away!
frank
