Broken off help requested
Roderick Jenkins | 18/02/2012 16:35:48 |
![]() 2376 forum posts 800 photos | Folks,
I have broken off the back gear key lever on my Super 7. I can't see how the lever is retained so that I can remove it to make a new one. Any advice gratefully received. Please see photos.
How did it happen? Well, I was playing with the bicycle speed display and had wound the VFD up to 3000 rpm. There was a magnet taped to the chuck which was making it out of balance. I guess that the vibration plus the speed flung the lever from its home position and it hit the headstock casting. cheers, Rod |
Nobby | 18/02/2012 18:39:01 |
![]() 587 forum posts 113 photos |
The lever on my super seven the arm is fitted on a taper and caan be tapped out from the back . I tried to upload a photo but with now luck |
Nobby | 18/02/2012 18:41:37 |
![]() 587 forum posts 113 photos | |
Roderick Jenkins | 18/02/2012 19:26:34 |
![]() 2376 forum posts 800 photos | Nobby, You're a genius. Eternal thanks, Rod |
