Countersinks angles
pgrbff27/01/2012 19:43:55
261 forum posts
31 photos
What angle countersink do I need for an M3 countersunk machine screw? Most seem to be 90 degree.
Any sugestions on the best type of countersink to use on carbon/glassfibre sheet which I need to attach to an aluminium frame. I believe the general rule is highest speed possible with carbon fibre sheet.
Andrew Johnston27/01/2012 20:01:32
7061 forum posts
719 photos
Most British countersunk screws have head angles between 90° and 92°, so a 90° countersink will be fine.
Personally I use three flute countersinks; they seem to cut well without chatter. Both fibreglass and carbon fibre are abrasive, so ideally a carbide countersink, but if you're only doing a few then HSS will be fine. I'd limit the speed; if you go too fast you'll end up softening the resin, and countersinks seem more prone to chatter at higher speeds..
pgrbff27/01/2012 20:33:50
261 forum posts
31 photos
Thanks. I only have 4 holes to do.
At such a small size I imagine there won't be much time for the resin to overheat as long as the tool is sharp.
pgrbff19/02/2012 16:22:26
261 forum posts
31 photos
I enjoy the challenge of making parts for my model helicoters and have had great help on this site with learning how to perform simple engineering tasks. My problem is that whilst I enjoy the practical side, I don't have my own machines and rely entirely on using a neighbours workshop. Add to this that I usually end up buying my own tooling and large pieces of stock, it works out extremely expensive. What is the best way to find a small workshop that is happy to perform small jobs? The drawing below is an example of the type of parts I need.
elanman19/02/2012 16:31:28
47 forum posts
4 photos
Hi,
For work on carbon you need a carbide or better still a diamond cutter as HSS has a very short life. Another way I have found OK is to make a solid point on a piece of MS or alloy bar and super glue some wet and dry abrasive paper to it. It does not last long but it's cheap and the paper is easily replaced. When counter sinking I use a hand brace, that's fast enough.
Cheers
Edited By elanman on 19/02/2012 17:02:12
Another JohnS19/02/2012 17:06:38
842 forum posts
56 photos
All metric countersunk screws should be 90 degree.
You might find that the North American screw threads are 82 degrees; although I live where the UNC/UNF reign supreme, I use solely metric, so don't quote me on other threads, like BA and ME!
I generally use a 90 degree countersunk; most of mine are about 6 flute. Take it slowly for metal, the cutting surface is rather large. (don't know about fiberous non-metalic surfaces)
In theory, you should have a countersink that matches the OD of your screw head so that there is a very slight parallel where the widest part of the screw head is, so that the screw head goes flush, but the countersunk hole does not look overly large. I generally just don't bother worring about this part!
Another JohnS.
KWIL19/02/2012 17:53:53
3681 forum posts
70 photos
pgrbf,
Even if you can find a "local" jobbing workshop, you will still be paying for minmum purchase of material to suit your job and also be paying their overhead costs (wages, rent, tooling etc), so I doubt it willbe cheaper for small jobs.
K
pgrbff19/02/2012 20:03:17
261 forum posts
31 photos
If I could find somewhere local I'd be happy. I can't!
Even if tools and materials are relatively inexpensive, a company like MSC charges £10 for delivery to Ireland. So if I need a 2.05mm jobber, and can't get one locally, ordering from UK costs a fortune.
I'd rather give the money to someone who knows what they're doing and not have to worry about when my neighbour will have time to help me out.
