X Y Z Axis
david newman 910/12/2011 18:12:47
47 forum posts
I often see on milling machine topics X Y Z axis what does this mean, I have worked out that it is movement in various planes but which does each letter donate ??? David
JasonB10/12/2011 18:18:32
X= side to side table movement
Y= front to back table movement
z= up/down quill or table movement.
J
david newman 910/12/2011 18:52:08
47 forum posts
Thanks Jason for explaining. David
Brian Price15/12/2011 14:09:18
8 forum posts
There is also a brand of milling machines called XYZ, see http://www.xyzmachinetools.com
I have used them in the past and was reasonably impressed with them.
I would add to the above, it is strictly speaking the relative 'cutter to table movement' as some machine the cutter moves and not the table. this is especially important when deciding whether the movement is say plus x or minus x.
i always think of it referring back to graph paper and if the cutter is at X=0 and Y=10 and you want to go to X=+10 and Y=0 then either the cutter has to move to the right 10 or the table to the left 10
I hope this helps Brian
