Heating equipment for boiler making
Kevin Norman13/11/2011 22:26:21
34 forum posts
I am coming to the point of building the boiler for my Sweet Pea and am not sure what brazing torch equipment to purchase.I know that they say you get what you pay for but I can purchase from a well known supplier a gas torch kit for approx £70 whereas the more expensive supplier it would cost in the region of £400.As I would probably build at the most 4 boilers with the equipment would the cheaper one do the job?
Nicholas Farr13/11/2011 22:33:07
3988 forum posts
1799 photos
Hi Kevin, without knowing the specs for the the two sources of equipment, its not easy to say, are they both identical pieces of gear?
Regards Nick.
Kevin Norman13/11/2011 22:40:04
34 forum posts
thanks Nick,
The only difference in the specs that I can see is that the expensive one has 8 nozzles as opposed to 5 and it also has a hose failure protection.
Regards Kevin
Terryd14/11/2011 04:16:12
1946 forum posts
179 photos
HI,
you can get a basic Sievert burner kit from here. They are much cheaper than most. If you check the spec. it is the same as that sold by Reeves. There is only one nozzle supplied but other nozzles can be purchased seperately if and when needed thus spreading any cost.
Terry
Stewart Hart14/11/2011 10:33:31
674 forum posts
357 photos
Hi
I built my boiler with the use a two burners, one a cheap and chearfull the other a more expensive, the trouble with the cheap ones is they blow out when you're trying to work in an enclosed area, (fire box) I used the cheap one for background heat to get heat into the bulk of the boiler and the expensive one to get the heat into more localised areas. Thats what worked for me.
Stew
Kevin Norman14/11/2011 15:13:05
34 forum posts
Thanks all for your answers , I think that I will go with TerryD's suggestion and go for the better quality Sievert gear as the Clarke looks cheap.
Regards Kevin
Stub Mandrel14/11/2011 20:01:21
4318 forum posts
291 photos
FWIW I have the basic Clarke set, and the biggest standard burner coped OK with a ~8" by 4" diameter centre flue boiler. I keep meaning to but a bifgger set of burners (set of three with a free handle, tube & regulator for the prioce of a single sievert burner)
Terryd14/11/2011 21:26:03
1946 forum posts
179 photos
Hi all,
the Clarke basic set and the Sievert kit is much more expenxsive from Machine Mart that the company I offered the link to. The Sievert kit from them is a very good bargain.
Terry
mgj15/11/2011 11:00:54
1017 forum posts
14 photos
Terry - thank you for that contact. The soldering burner will be very handy when doing TE tenders.
You will need a cyclone type burner to deal with silver soldering in confined spaces. That is not cheap or expensive - that's a specific type of burner. Sievert do them for certain - others probalby.
You also need the right regulator. You could I guess, do a boiler with a 2 bar regulator, but I would think that most people doing that sort of work would use a 4 bar one.
Kevin Norman15/11/2011 11:20:24
34 forum posts
Thanks all for your tips,
I have now purchased Sievert equipment from Hamiltons gas products for £125 which was approx half the price of other suppliers.
Kevin
oldhandmike19/11/2011 18:51:56
2 forum posts
Kevin, thank you for posting this subject I have sent you a related Message which you can pick up from within you Account.
Richard Parsons20/11/2011 08:22:20
645 forum posts
33 photos
Kevin,
When I lived in the U.K I used Sievert gear for all my work. When I came to Hungary I had two problems (apart from the language and the Hungarians). Firstly I had to get a new regulator. Hungarian cylinders have a left hand Male fitting. I did make a converter for the Sievert regulator but I could not get it ‘Officially’ tested. The gas people over here used to test gas appliance FOC. Now they do not. I know the thing was gas tight but if I used it and my neighbours house caught fire I would be blamed. Secondly the propane/butane mixture the sell is very dirty. I used to get a huge black mass of flux residue and leave a black sludge in the pickle bath. I had seen it before in the UK using one supplier’s gas bottles, but nothing like the amount I get over here.
I bought from the U.K a Flamefast torch (usual disclaimer) which uses gas/compressed air. It is very good, no more black residues and a ‘coconut every time’. It even works on ‘Earth Gas’ (natural gas). To my mind the gas/air torches are well worth the investment as you only need one burner to do all but the smallest jobs.
Rrgs
Dick
Edited By Richard Parsons on 20/11/2011 08:24:09
