Eric Cox | 04/11/2011 09:16:36 |
![]() 557 forum posts 38 photos | ME 4415 Drawing 2 If you add up the lower dimensions of the main frames it differs from the overall length of 15.625. |
Eric Cox | 05/11/2011 12:33:33 |
![]() 557 forum posts 38 photos | A review of the above post. After inquiring about water cut frames for the gauge 3 Dee the following errors emerged. The overall length of the main frames is given as 15.625" but if the individual dimensions at the bottom of the frame are added together, the overall length works out at 15.7195" On the tender frames the length is 11.063" but the individual dimensions give 11.064" The tender dimension is only a thou out but which dimension is correct on the main frames. |
Dick Allan | 12/11/2011 15:30:13 |
14 forum posts | Hi Eric Sorry for the slip. The length between the inner ends of the bogie wheel arches should read 1.437 and between the middle of that dimension and the forward end should read 3.031. These changes have been notified to SCISS so the cut items should be correct. If you care to email me I will send you a new drawing - [email protected] |
Stub Mandrel | 12/11/2011 16:55:16 |
![]() 4318 forum posts 291 photos 1 articles | This is the real reason for measuring all dimensions from a single datum - you never have two ways of adding up the same distance so no-one can catch you out ![]() Seriously though, it's one reason I like using nice round and fractional measurements because these sort of errors (which we all make) stand out more easily, at least to me. Neil |
Dick Allan | 12/11/2011 17:07:46 |
14 forum posts | Hi Neil Interesting! Actually the error arose because during construction of the loco I adjusted the position of the bogie, corrected my latest drawing but failed to communicate it to ME. Another point in favour of what you suggest is that it helps the laser and water cutting guys to set up their machines. Trouble is, old habits die hard! Dick |
