Mechanically polishing steel castings
flintlockand steel27/10/2011 18:14:10
26 forum posts
Hi
I frequently need to polish up new steel castings and the supplier recomends and uses a "very very soft" stainless steel brush like really fine wire wool mounted on a grinder.
Does anyone know where I can get these in the UK?
PS the supplier couldn't find the manufacturer's details so I'm asking here
JasonB27/10/2011 18:26:27
If it actually like a wire brush eg actual straight hairs or a stainless wirewool that can be mounted in a die grinder, if the later then it sounds like a "surface conditioning disc" which can be had in different grades to get say various brushed finished on stainless steel etc.
J&L do various brushes that can be used in a die grinder down to 0.003" stainless wire probably similar thickness to size 0 wire wool
J
Edited By JasonB on 27/10/2011 18:31:32
Edited By JasonB on 27/10/2011 18:35:22
flintlockand steel27/10/2011 20:07:46
26 forum posts
I believe the one my supplier uses is 100-125mm and mounted vertically on a bench grinder the same way a grinding wheel is.
I think if I knew the precise name or term for this brush I could find it. If I put in soft wire brush etc I get everything but the item I'm looking for
JasonB27/10/2011 20:28:47
Try looking for wire wheel
Osborn do a good range
J
