Morgan Sweet | 30/09/2011 08:23:02 |
20 forum posts | Please can anyone tell me the difference between a Super 7 and a Super 7B and are parts/tools available for these machines as I understand that Myford have ceased trading, Thanks for any information. |
NJH | 30/09/2011 09:06:35 |
![]() 2314 forum posts 139 photos | Hi Morgan Short answer - Super 7B is a Super7 with a gearbox. Some original spares are available from Home & Workshop machinery and we all await the new Myford web site which is being built - click on the Myford box at the righthand side of this page. Regards Norman Edited By NJH on 30/09/2011 09:08:45 |
Morgan Sweet | 30/09/2011 10:14:15 |
20 forum posts | Hi Norman
Thanks for the information, I have recently purchased a well used (from my work place) Myford Super 7 and it has a gearbox, although not all speeds work (no doubt someone operated it whilst lathe was still running) and I would like to restore it so I hope parts become available. The bed also has the usual workshop hacksaw cuts around the headstock end. I also need to convert it to single phase and wonder if to replace the motor or buy a Single phase to three phase inverter. Any thoughts ?
Best wishes
Morgan |
David Littlewood | 30/09/2011 11:09:52 |
533 forum posts | Morgan,
I would definitely recommend you keep the 3 phase and get a VFD. The advantage of this is that you have infinitely variable speeds, and can change on the fly. This means, among other things, that when facing a large diameter piece you can start slow and speed up as the diameter reduces. The motor is also smoother.
I Replaced the 0.5 HP single phase motor on my S7 with a 1 HP 3 phase + VFD (package from Newton Tesla) a couple of years ago, and the improvement is significant.
David |
NJH | 30/09/2011 11:57:33 |
![]() 2314 forum posts 139 photos | Hi Morgan Mine has a single phase motor which is fine so I find the expence of a change hard to justify but I do agree with David. In your situation I would certainly retain the 3 phase motor and benefit from the variable speed that the convertion would supply.. Regards Norman |
