Nobby | 07/09/2011 22:48:12 |
![]() 587 forum posts 113 photos | Why is the top slide at an angle ? Am I missing something Nobby |
Steve Withnell | 06/12/2011 23:24:32 |
![]() 858 forum posts 215 photos | It's a while back now. I think it was to do with getting enough movement on the cross slide. I normally have the topslide offset at 6 degrees, to give a x10 on the topslide dial, ie the feed is 0.0025mm/div instead of 0,025mm as calibrated.
I had to do the same thing when I turned the flywheel for the Victoria, I had to swing the top slide right round to get the tool to the edge of the work.
Steve
Nobby | 10/12/2011 12:04:49 |
![]() 587 forum posts 113 photos | Hi Steve Thank's .It looks great plunging in from the front with no support . There's the problem in my point of view is pitching the spacing off the grooves is there DRO on your lathe? Regards Nobby |
Nobby | 10/12/2011 12:06:12 |
![]() 587 forum posts 113 photos | Whoops I missed the fixed steady Its my age Nobby |
