Michael Gilligan | 09/07/2011 21:36:53 |
![]() 23121 forum posts 1360 photos | I was delighted to see that issue 179 is accessible on the iPad ... all previous issues require "Flash". Unfortunately my delight was short-lived: because the Zoom feature only allows access to the right hand page of each double spread [and the iPad's gesture zoom isn't implemented]. If anyone can offer a workaround, or tell me what I'm doing wrong, please respond. Thanks MichaelG. |
LADmachining | 09/07/2011 22:20:46 |
![]() 126 forum posts 11 photos | The new viewer uses flash as well.
I have just tried looking at issue 179 using IE, for which I do not have flash installed. It just gave an error screen saying I need to install flash player.
Maybe the lack of flash on the iPad is still causing you problems?
Michael Gilligan | 09/07/2011 22:27:56 |
![]() 23121 forum posts 1360 photos | Thanks for that ... there must be something really strange going on, because the iPad [which, as you know, doesn't use Flash] opens issue 179 as a "book". MichaelG. |
NeilC | 10/07/2011 19:34:37 |
7 forum posts | when you first open issue 179 on an ipad there is a box telling you "swipe your finger across the pages to browse the publication or double tap on a page to zoom in" works for me ok on iPad 1. I found that the "zoom" feature only works for the last last selected ( double tapped ) page. So if you selected / double tapped the left page only left pages will be zoomed with the zoom feature, if you had selected / double tapped the right page then only right pages will zoom. I find it works ok to swipe through to browse and then double tap on the page I want to zoom. |
Michael Gilligan | 10/07/2011 20:28:02 |
![]() 23121 forum posts 1360 photos | Thank you, NeilC Yes, it works ... I knew I must be doing something daft! MichaelG. |
Gone Away | 11/07/2011 01:17:54 |
829 forum posts 1 photos | Interesting, thanks for the heads up. Up to now I've been printing the mag to pdf on a PC and then transferring the pdf to the iPad and reading it with iBooks. I just tried this direct method and at first glance, I think I still prefer the pdf route....mostly because it will fill a vertical screen with a single (full) page which is readable (just) without zooming (you can still zoom in if you need to). When I tried the direct method I either got a full page that only filled half the screen or I got part of a page when I zoomed. Admittedly though, I only tried for a few minutes so I may be missing something. |
