edwood | 15/03/2011 12:49:33 |
12 forum posts | hi
i have drawings for a verticle boiler that is of riveted construction ,i have know idea of how to rivet. is it possible to silver solder and fit dummy rivets.
hope someone can help.
regards edwood
JasonB | 15/03/2011 13:18:50 |
![]() 25215 forum posts 3105 photos 1 articles | It would be possible to insert silver solder foil between the mating parts to give the correct gap for the solder and then insert rivits with the heads on the outside and just lightly deform the inside of the rivit to hold it in place. The whole lot could then be soldered.
You would need to ensure the flange widths were suitable for silversolder and if you intend to use in public have a word with your club inspector first as if the barrel is a lap joint ne may want to see a butt joint with strap.
J |
edwood | 20/03/2011 16:24:23 |
12 forum posts | thanks for the advice jason it sounds like a good idea i would have a fully solderd boiler and still have the rivets for show. the boiler is for a dairy engine so would not be used in public.thanks again jason and sorry for the late reply
regards ed
