Member postings for edwood
Here is a list of all the postings edwood has made in our forums. Click on a thread name to jump to the thread.
Thread: riveting advice
20/03/2011 16:24:23
thanks for the advice jason it sounds like a good idea i would have a fully solderd boiler and still have the rivets for show. the boiler is for a dairy engine so would not be used in public.thanks again jason and sorry for the late reply
regards ed
15/03/2011 12:49:33
hi
i have drawings for a verticle boiler that is of riveted construction ,i have know idea of how to rivet. is it possible to silver solder and fit dummy rivets.
hope someone can help.
regards edwood
Thread: hardening and tempering
05/02/2011 20:39:04
hi
a trick i read years ago in a gunsmiths book. when try ing to heat up a job say a reamer you have made that goes to a very fine point and you burn the end off trying to heat it evenley. heat a tin of lead lower the job in it will heat it evenly ready for quenching .hope this is of use to someone
regards ed
ps lets have a few more tips theres thousands outthere .and they make life a bit easier
Thread: warco mill help needed
02/11/2010 15:45:29
hi
   my lathe is a chester db7 with a3.5 center hight and a mt 3 mandrel so i will go for an er32 system and hopefully get the best of both words,anyway whats another weeks pension in a search for happiness
many thanks ed
                      strangers are only friends you havent met
01/11/2010 21:20:59
hi dusty
 the mill i have is the warco mini mill drill it was bought new from warco two months ago when the head is at its lowest position there is about 3.5 inches from the bed
chronos do a posilock collet system chuck and eight  collets for£85. also a soba system
with 15 er colletts and chuck for £115. warco are about £99 for chuck and 4 colletts
any advise on the best one to go for, as havent a clue
        ed
01/11/2010 14:19:58
hi
thanks everyone for your advice i cant see anyway of lowering the head,so i will go for buying a proper chuck and collets.i like the idea of makeing a sub table sounds very usefull.
                   once again thanks for your advice regards ed.
31/10/2010 22:16:18
31/10/2010 22:15:41
hi
i have recently bought  a warco mill drill and some mt3 collets .every thing ok working in the vise but cutter wont reach workpiece when on the bed am i doing somthing wrong or do i need to extend the cutter somehow hope somebody can help
many thanks ed
31/10/2010 22:15:37
hi
many thanks ed
31/10/2010 22:13:33
hi
many thanks ed
Thread: canterbury lamb
02/10/2010 20:18:48
hi nick
thanks for the info if i decide to have a go at this project i will take your advice and make the boiler out  copper sheet .or with a small bribe i will get my son to roll it for me,he,s a sheet metal worker many thanks for your advice.
                          regards ted
01/10/2010 20:41:04
hi all
would like some advice on the canterbury lamb,as my first locomotive build does the boiler have to be rolled or would copper tube of the same size do .as ihave no rolling equipment .i have built marine engines in the past,and have just bought a mill so would like to build somthing a bit different
                             regards ted
