"Potty" radial engine
Eric Cox19/02/2011 10:01:34
557 forum posts
38 photos
In ME 4397 the general arrangement on page 197 shows the component list but the identification numbers are missing from the drawing.
Why make the crankcase out of 1 3/4" A/F when the largest available stock size appears to be 1 1/2" A/F.
Nicholas Farr19/02/2011 10:19:39
3988 forum posts
1799 photos
Hi Eric, I guess thats why it was machinced from round bar stock. Don;t know about the I D numbers.
Regards Nick.
Eric Cox19/02/2011 10:31:26
557 forum posts
38 photos
Obvious when you think about it.
Also, the photo no 2 shows the surface between the two under cuts where the cylinder hole breaks through appears to be curved and not flat or am I interpreting the drawing wrong.
Nicholas Farr19/02/2011 10:52:37
3988 forum posts
1799 photos
Hi Eric, you are looking at a cross section, where the outside is flat and the inside is a round bore. If you actually cut the piece thruogh and looked at it in this way, that is how it will look at a point blank view.
Regards Nick
Stewart Hart19/02/2011 11:44:32
674 forum posts
357 photos
Hi
My assembly drawing did show the part numbers but for some reason they were left off at the editing bench, I also spotted that they show some holes on the crank case as 3mm when they sould be M3 also changed at editing.
Any one wanting a set of my own un edited drawing can send me a PM with email adress and I'll send them a copy.
Stew (Potty)
Tony Case 108/03/2011 16:59:49
1 forum posts
No credit given to ET Westbury ? (Cygnet Royal)
Maurice10/03/2011 22:29:55
469 forum posts
50 photos
Hi,
I echo Tony Case's reference to E.Westbury,s Cygnet Royal. I also have a question about Potty. Why does a steam engine need cooling fins?
Coxy.
John Olsen11/03/2011 06:03:37
1294 forum posts
108 photos
I will make a wild guess that it is because Stewart wanted it to look like an aircraft engine. The fins are of course a disadvantage when running on steam, but will be of benefit when running on compressed air, and I suspect that many engines of this type (eg small stationary engines.) spend more time on air than steam, so maybe it is not a bad idea.
regards
Stewart Hart11/03/2011 07:31:30
674 forum posts
357 photos
The rotary valve is based on the great ET Westbury,s Cygnet Royal along with the overall scale, I modified the crank to ease manufacture and redesigned the con rods and crank case, and sculpted the cylinders to look like an aircraft engine, as John said the finning has no practical use.
There are a number of similar designs of engines about, I was also influenced by an engine on John Tom http://www.john-tom.com/ :-there are very few things that don't evolve from what has gone before.
I tried to show in the article an engine that could be made from bar stock without the use of castings.
I answered all question from ME honestly about the design.
I doubt that as a steam engine the concept would have any practical use, however if you turn it on its head and coupled it up to an electric motor the concept is used for compresors/pumps.
Stew
