Cyril Bonnett | 14/02/2011 00:46:06 |
250 forum posts 1 photos | Hi
If you are searching google try this model engineer filetype ![]() The model engineer can be anything you are searching for following by filetype: then the type of file you are looking for ie pdf in this case
Cyril |
Stub Mandrel | 25/02/2011 21:47:49 |
![]() 4318 forum posts 291 photos 1 articles | Google won't let me type smileys :P Neil |
dixie | 26/02/2011 11:04:38 |
31 forum posts | Hello all, beware of this link I used it and the computor warned me of mal ware I instantly clicked quarantine but still got over 100 files infected when the scan was run. What do these bimbos get out of doing this. |
David Clark 1 | 26/02/2011 15:35:19 |
![]() 3357 forum posts 112 photos 10 articles | HI There
What link?
Is it on this site?
If so, I can delete it.
regards David
Billy Mills | 26/02/2011 16:30:16 |
377 forum posts | If you google search help you get a very helpful selection of tips about searching e.g. a minus sign excludes whatever follows. Well worth looking at if you use search engines. Google guide lists all of the valid search options including filetype: (filespec) -which is a perfectly valid and safe option that can save a lot of time. There are a lot of options. Regards, Alan PS had the same attack of the smiles as the original post , perhaps it's a colon then brackets eg ![]() Yes it is! Edited By Alan Gray 1 on 26/02/2011 16:37:05 Edited By Alan Gray 1 on 26/02/2011 16:37:48 Edited By Alan Gray 1 on 26/02/2011 16:39:47 Edited By Alan Gray 1 on 26/02/2011 16:41:08 |
