Press Button Oilers
ChrisH16/01/2011 15:06:00
1023 forum posts
30 photos
I have an 8mm press button oiler on the lathe that is 'broken' and needs replacing.
Does anyone have a good suggestion on how to remove it without damaging the bit of the lathe it sits in?  The oiler seems to be a very tight fit in it's hole.
ChrisH
JasonB16/01/2011 16:46:28
Find a tap that suits the hole, cut a thread and then use a bolt to pull it out. ARC sell new ones. Or if you have a small stud extractor use that.
Jason
ChrisH17/01/2011 00:04:07
1023 forum posts
30 photos
Thanks for the reply - I was thinking of using a stud extractor, the 'cut a thread and use a bolt' is the next progression onwards.  I will see how it works!
Chris
Terryd17/01/2011 09:41:20
1946 forum posts
179 photos
Hi Chris,
Just a thought. You could cut off the 'head' or flange of the oiler by using a countersink in a hand drill similar to cutting the head of a pop rivet when removing.  Then if necessary carefully drilling out the body of the 'cup' in stages until the shell is thin enough to be able to collapse inwards then use a pair of snipe nose or round nosed pliers to pull out the remains.
Terry
P.S. the hole made by the countersink would release the ball and spring inside.
T
P.P.S  The taper on an extractor may expand the body and jam the oiler perhaps?
T
Edited By Terryd on 17/01/2011 09:45:29
ChrisH18/01/2011 13:47:52
1023 forum posts
30 photos
This morning I had a go at getting the oiler out and thought that the stud extractor was the easiest method to try as a first go.  I had tried this some time ago without success and given up, but obviously I wasn't trying hard enough, as a good go this morning with the extractor and out it came.
So, to Jason and Terry - thanks for the advice.
Chris
