Ralph Koch | 08/11/2010 15:20:18 |
6 forum posts | I would like to hear some experience from others with these two trademarks. I already have a Q-kit from Greenwood that i'm satisfied with, and would like to invest in some more indexable tools. I could be tempted to buy some Glanze tools because they are much cheaper, but maybe it was better to invest a little more and buy from Greenwoods. |
KWIL | 08/11/2010 15:36:14 |
3681 forum posts 70 photos | The Glanze toolholders are OK but I would stick to Greenwood for tips. I have bought from both companies. Glanze (made in India) is marketed by Chronos of course. |
Engine Builder | 08/11/2010 21:53:09 |
![]() 267 forum posts | If you want to try a superior tip try Sumotoyo from carterprecisiontools.co.uk. I have no connection with the company but have been using these tips for 15 years and wouldn't touch anything else. David |
Ralph Koch | 09/11/2010 13:37:02 |
6 forum posts | It's nice with a second opinion. I think the inserts from Greenwood comes from Sandvik a swedish company with high respect. |
Martin W | 09/11/2010 14:45:54 |
940 forum posts 30 photos | Hi
I bought some Glanze tools from Chronos some time ago, they take the TCMT 11 series tips. I have used both Sandvik and Kenametal tips and have found both these cut well producing a good finish on most materials. If you look at the Sandvik catalogue, available on line at Sandvik, they recommend various types and grades for different materials. That said I have not followed their recommendations, cost and having to hold many different tips, and found that they all seem to cut very well whether roughing or fine cutting. I have however bought various tip sizes ranging from 0.2mm, 0.4mm and 0.8mm in order to meet specific requirements of some jobs.
Generally I have been very satisfied with the results but still use HSS tools and solid carbide depending on circumstances. I initially found that turning with insert tools took a little bit of getting used to but varying the speed and cut depth soon overcame these problems.
Hope this ramble helps
![]() Cheers
Martin |
