david coyne | 28/08/2010 18:18:48 |
1 forum posts | hi there has anyone got a chester model b super lathe as i would like some advice as i have just bought one pleas can you help thanks Dave |
Martin W | 28/08/2010 18:25:37 |
940 forum posts 30 photos | Dave
Have you looked at or asked this question on the Chester UK site forum. There are a number of people there who use the Model B and will have experience. Not only that but there are several threads that are specific to Model B.
It might be worth posting something similar there if you haven't already done so
![]() Cheers
Martin
Edited so many times cause I have got dyslexic fingers again
![]() Edited By Martin W on 28/08/2010 18:29:17 Edited By Martin W on 28/08/2010 18:31:20 Edited By Martin W on 28/08/2010 18:33:20 |
John Stevenson | 30/08/2010 22:15:40 |
![]() 5068 forum posts 3 photos | Posted by Martin W on 28/08/2010 18:25:37: Martin Edited so many times cause I have got dyslexic fingers again ![]() Edited By Martin W on 28/08/2010 18:29:17 Edited By Martin W on 28/08/2010 18:31:20 Edited By Martin W on 28/08/2010 18:33:20 . Funny that. I have a dyslexic keyboard ? John S. |
Martin W | 30/08/2010 23:44:34 |
940 forum posts 30 photos | John
Your keyboard and my fingers and we have a new engineering language.
All the best
Martin |
Stewart Hart | 02/09/2010 07:28:38 |
![]() 674 forum posts 357 photos | Hi David
I've had a model B for over 10 years now, and have managed to produce some good work, but like all machine tools it has its good and bad points.
The worst thing with it is the lack of rigidity in the mill head, you have to try and keep your sets ups as short as possible don't over extend the quill, take small cuts 1/2mm is about the max in steel. About 18 months ago I bought a small mill, and took the mill head off blanking off the hole left and now just use it as a lathe, which I think is great.
Best part about the lathe function is its huge swing though it hasn't got the torque to turn anything really big, but it gives you plenty of room to workaround, Thread cutting up to a shoulder is not easy with a minimum speed of 90 rpm, but I get round this by running the lathe in reverse and with the tool at the back, cut from the shoulder out. The drive belts as supplied are crap I wore them out in just a few months, replaced them with a standard belt from my engineer supplier that I'm still using.
I've done a few mods:- fitted a vertical DRO to the mill which added to its accuracy greatly. Added some grub screws to the tail stop quill that engage with drill tangs so can take heavier cuts. Added thrust bearing to the cross slide lead screw reducing back lash greatly with a smoother action and greater repeatability.
Having said all that the most inportant thing is to try and get the best out of your machine as you can and to enjoy your model engineering
Her's a few pics of what I've made
Cheers
Stew
Edited By Stewart Hart on 02/09/2010 07:30:26 |
Rob Whight | 16/02/2014 09:33:09 |
3 forum posts | Stewart,
Any clues on the specs of the drive belts ? Whilst mine do have a few numbers on them (they are the original ones I got with the machine), I can't seem to find a suitable one on the web.
Cheers, Rob |
Stewart Hart | 16/02/2014 16:35:59 |
![]() 674 forum posts 357 photos | Hi Rob No Idea about ref number I took mine along to my local engineer suppliers and asked for an equivalent they put it on gauge that measured the circumference and handed a Ferodo one over fit perfect been on the machine for 6 years now.
Stew
