Boiler fittings
David Paterson 423/08/2010 04:25:03
83 forum posts
8 photos
Hi,
can anyone point me at a set of plans that reasonably caputes the fittings I need for a 3" vertical boiler. I plan on making the fittings rater than buying. I have bought samples of nuts and tails but not the more expensive ones.
From a copy of the magazine i pick up off the stand it looks like the Shand fire engine is on the right track; but my new subscription wont catch the relevant aticles. (would need to know the relevant back issues)
also, as a first time boiler, I have a few doubts (under steam pressure) about a valve rather than a 'tap' design for the various valves.
thanks david
Edited By David Paterson 4 on 23/08/2010 04:25:20
JasonB23/08/2010 07:22:08
"also, as a first time boiler, I have a few doubts (under steam pressure) about a valve rather than a 'tap' design for the various valves."
The valve should be designed so the steam pressure holds the spindle down onto its seat in much the way that a stopcock in your house is directional so the water pressure will hold it shut rather than trying to lift the washer off its seat.
If you are now a subscriber you should be able to view the mags by going to "digital issues" in the "my Account" box
Jason
David Paterson 423/08/2010 09:39:10
83 forum posts
8 photos
Thanks,
The valve design I have concerns about has a tapered seat with a cross hole, this design is in the Shand Fire Engine to close the drain cock on the water tube so would need to hold steam pressure. Other valves seem to be a needle into a tapered hole. Niether design fits your rather logical description.
regards
David
JasonB23/08/2010 10:44:29
This is the typical type of valve used for drain cocks, there are thousands in use, so long as you make the tapered reamer at the same topslide setting as the spindle you should not go far wrong
Jason
