Narrow Gauge Loco "Eric" by Brian Wilson
Donald Mitchell12/07/2010 21:00:49
90 forum posts
Hi Engineers all,
Is anyone out there building, or has built the loco called "Eric" described in the book "Steam Trains in your Garden" by Brian Wilson?
I have a query about the crossheads which I hope someone who has built the loco might be able to answer.
Donald Mitchell
Castle Douglas
Bonnie Scotland
peter ravenscroft13/07/2010 16:49:48
100 forum posts
hi donald
                i'm building an eric but it is on hold a t moment while i tackle a darjeeling loco
if you log onto steammodelloco16mm yahoo group there is a lot of people there building eric  and if you ask you will find the answer.
 Brian wilson is a member so you can ask him direct if you wish but you will probably find your answer in the files section they are a great bunch on there very frendly
regards
peter
Donald Mitchell13/07/2010 18:54:07
90 forum posts
Thank you Peter for your lead to the Yahoo group. I have duly joined up and it looks to be just what I'm after for help.
Raymond McMahon tells me that you had a great conversation about the Darjeeling Class B loco. Good luck with its construction.
Donald Mitchell
Castle Douglas
Bonnie Scotland
Eddie Price 113/07/2010 19:48:23
19 forum posts
4 photos
Hi Donald and Peter.
I have just completed an Eric, but I am having a problem with the burner and am currently planning to experiment with a radiant heater type burner. I will let you know how I get on.
The Steammodelloco16mm group should certainly be able to help.
Eddie Price
Eddie Price 113/07/2010 20:26:53
19 forum posts
4 photos
Hi all.
I have placed a photo of my Eric in the album. I am not sure how to direct you directly to it from here, so you will have to search for it.
Eddie Price
Donald Mitchell13/07/2010 22:29:01
90 forum posts
Hi Eddie,
I see your Eric, looks almost finished, and nice in dark red.
I have only just begun my Eric and have decided to make the six coupled with trailing bogie version, it'll probably take me years because I have about four  other projects all on the go at once.
Minnie nearly finished, Clayton nearly finished, 5cyl radial I.C. aero engine half made, I hope I live long enough.
My question with the Eric is this; on the drawing for the coupling rods it shows the small end of the rod as having a 2.5mm hole through it, yet on the drawing for the crosshead pin which holds the small end of the connecting rod to the crosshead, the pin is shown as being being 3.2mm (or 1/8") dia.
Any ideas what it should be; I tend to favour going with the 3.2mm (or 1/8") dia. choice.
Happy engineering.
Donald Mitchell
Castle Douglas
Bonnie Scotland
Eddie Price 114/07/2010 09:02:43
19 forum posts
4 photos
Hi Donald
If you have joined the Yahoo 16mm group you will find in the files section a list of corrections to the book. Look for Steam Trains in Your Garden - Everything you need to know. Then look for ericcorrection.pdf for a list of corrections. Basically you are correct in saying you can drill 3mm and then make the outer radius of the con rod 3mm.
Yes I have got a part finished Minnie, plus various marine engines in various stages of completion.
Good luck with Eric.
Eddie
Geoff Theasby14/07/2010 17:31:25
615 forum posts
21 photos
If you are building a locomotive called "Eric", shouldn't you be building it  Little by Little?
Geoff
Donald Mitchell14/07/2010 17:50:02
90 forum posts
Thank you Eddie for your pointer to the ericcorrection.pdf - I see that others have had the same problem with various valvegear pins; 3mm is obviously the way to go.
Geoff, I honestly have no idea what your "Little by Little" reference alludes to in connection with "Eric"?
GM4TPR
Donald Mitchell
Castle Douglas
Bonnie Scotland
Geoff Theasby15/07/2010 14:46:36
615 forum posts
21 photos
Sorry, Donald, it was an attempt at humour.
It is the title of a 19th Century book by Frederick Farrar, read about it on Wikipedia.
Geoff, G8BMI
Donald Mitchell15/07/2010 18:54:38
90 forum posts
Geoff, thank you for your explanation.
I was beginning to think I was a bit thick by not seeing the joke but when I note that the book "Eric or Little by Little" was published in 1858 I think I may be excused for not making the connection right away.
Donald Mitchell
Castle Douglas
Bonnie Scotland
