Hall Effect
Hall effect ignition system
dixie19/05/2010 20:55:05
31 forum posts
Can any one tell me where I can find information on installing electronic ignition in miniature i/c engines.Have found several web sites but they all seem to think every body understands electronic jargon. I'm surely not alone in this, village idiot  type speak please.
MichaelR20/05/2010 09:20:14
528 forum posts
79 photos
Have a look on this site Here they stock ignition systems and have full fitting instructions on a PDF file you can read.
Also this may help Here
JasonB20/05/2010 10:24:31
Its really very simple with a hall effect sensor. You just need to fix the sensor and arrange for the small magnet to sweep accross its face. So that means the magnet can be glued into a small hole in say the flywheel boss or timing gear and the sensor to a non moving part of the engine. If you want to be able to advance & retard the timing then the sensor is best on an adjustable disc that can be rotated around the engine axis, Thats what I did on my hit & miss engine.
You then just run a earth from the engine to circuit board and a plug lead to the plug.
Here is another site with some set up instructions
J
dixie20/05/2010 19:27:24
31 forum posts
Many thanks to Jason and Stick for their help, maybe I will get myself sorted now. Once again thank you for taking the time
