Reverse an electric motor
Mike Bishop21/04/2010 20:21:49
2 forum posts
I have recently aquired a fractional hp single phase motor for my lathe and need to reverse the direction of rotation. What is the correct way? I dont want to cross belts.
V8Eng21/04/2010 21:00:12
1826 forum posts
Apologies if you've already checked this: some manufacturers fixed an instruction slip in the connection box lid.
Engine Builder21/04/2010 21:23:43
267 forum posts
The motor should have 4 wires comming out of the inards and into the terminal block. It will have 2 seperate windings which can be identified with a multimeter. With the meter on the ohms range you will get a reading between the 2 wires comming from each winding . You need to reverse the connections to one winding only.
Edited By Engine Builder on 21/04/2010 21:47:07
Mike Bishop25/04/2010 08:59:29
2 forum posts
Many thanks Engine Builder, your info was correct and achieved the required result. Regards
Mike Bishop
