Chris Trice | 15/04/2010 23:44:05 |
![]() 1376 forum posts 10 photos | On the basis that no question is too stupid, on both the DTI's I own, the bodies have slotted dovetails, presumably for mounting in an appropriate dovetailed fitting but I can't find any information on the fittings or how they're mount onto a lathe/mill. Fortunately both come with a little black arm I can fit into the toolpost of the lathe and there's a stem at the top which I can mount in the chuck/collet of the milling machine but I was curious to the use of the dovetail and if it's worth investing in the extras? |
chris stephens | 16/04/2010 00:13:00 |
1049 forum posts 1 photos | Hi Chris,
I assume your DTI's are Verdict, if so go to the following link which will show you a page from their catalogue.
chriStephens
http://www.mjallen.co.uk/library/catalog/Metrology/DTI%20Attachments%20and%20Accessories.pdf |
Circlip | 16/04/2010 12:31:27 |
1723 forum posts | A little "Attatchment" for you to make and worth the effort
Use HE30 or 6082 for the material
Regards Ian
THIS link works Chris.
Oh yes, if you machine it correctly, you don't need the 1.3" long slot in the bottom left hand view. Edited By Circlip on 16/04/2010 12:33:21 |
Chris Trice | 16/04/2010 22:28:10 |
![]() 1376 forum posts 10 photos | Thanks guys. Yes, they are Verdict DTI's so both links are quite relevant. If you copy and paste that first link, it works fine. Thanks again. |
