Ian Lee | 29/09/2009 22:32:45 |
53 forum posts | Can ayone tell me what the dimensions are for the spindle nose on an ML7 , I want to make an adapter for one of my ER32 collet chucks which was made fit on a Myford.
I am making the adapter to fit the chuck on a spare Cam lock backplate on my Chester Conquest lathe.
I need the thread pitch and diameter and the diameter and recommended lenght of the location shoulder.
mgj | 29/09/2009 23:28:37 |
1017 forum posts 14 photos | The register diameter you can measure, and the depth will be measurable too, less an allowance for the threading runout groove. You will need to turn to 1.250 +.00002/ +.00005 if you want it to really run true. (Keep it well oiled with 3:1) As long as it clears the actual depth of the register is not critical. The ones I have cut for mounting stuff on a VDH, and putting a boring head into the Dore Westbury have had registers about 1/2" long. The one supplied on the BS0 dividing head, which is perfectly secure is not much more than 3/8" long. The thread is 1 1/8 x 12 55deg Whit form, but you wil need to ensure the crests are truncated a fraction, to be sure it doesn't hang and the register and back flange are doing the aligning.. |
mgj | 30/09/2009 00:18:35 |
1017 forum posts 14 photos | Can you correct the dimensions - I've put the decimal point in the wrong place. +2 tenths of a thou to + 5 tenths. Apologies Edited By meyrick griffith-jones on 30/09/2009 00:18:52 |
David Haythornthwaite | 30/09/2009 10:21:01 |
![]() 45 forum posts 7 photos | If it helps, I made a collet adapter as you are making and I kept the measurements that I used for this. I will email you and attach a Jpeg of the details. If you can get hold of MEW Feb 99, Giles Parkes details the dimensions of an adapter, but if you use this BEWARE - the boss needs boring out to 1.018" for screwcutting NOT 1.108" as printed in the article. |
mgj | 30/09/2009 12:07:36 |
1017 forum posts 14 photos | Damn -put it down to a streaming cold and late at night. the thread is 1.250 x12 whit and not 1.125x12. Should have known because I only did one only the other day. Got myself totally crossed up there.Pity there isn't a delete post facility. Buy a Model Engineers Handbook (3rd edition)by Tubal Cain. The dimensions are in there as is all the threading data. Edited By meyrick griffith-jones on 30/09/2009 12:09:18 |
John Stevenson | 30/09/2009 12:17:43 |
![]() 5068 forum posts 3 photos | Posted by meyrick griffith-jones on 30/09/2009 12:07:36: Damn -put it down to a streaming cold and late at night. the thread is 1.250 x12 whit and not 1.125x12. Should have known because I only did one only the other day. Sorry ?? Myford thread is 1 - 1/8" x 12 Whit form, Register is 1 - 1/4" John S. |
Ian Lee | 30/09/2009 18:16:01 |
53 forum posts | Many thabks to all for the info I'm hoping to start on the adapter tonight providing grandad duties don't get in the way |
mgj | 30/09/2009 19:41:39 |
1017 forum posts 14 photos | Still got the streaming cold ![]() I really got myself into a tiswas over this one. Anyway mine did fit fine first time, so perhaps the doing is easier than the writing. Apologies. |
