Dave Jones 1 | 15/09/2009 19:38:19 |
85 forum posts 5 photos | just a quick question. Due to the cost of brass, I was thinking about making a tender body from steel (then painted inside and out) is there any reason why I should not do this? (i.e. will it eventually rust) |
Ian S C | 16/09/2009 12:27:35 |
![]() 7468 forum posts 230 photos | I don't know much about model locos,but maybe you could get it galvanized. |
PETER AYERS | 19/10/2009 14:33:07 |
![]() 25 forum posts | a friend of mine has a loco which is quite a few years old, it has a steel tender painted indide with bitumen paint and there is no sign of rusting. Hope yhis helps Petera |
Laurence B | 20/10/2009 09:43:13 |
58 forum posts | I'm building the tender for a Don Young Class 2 at the moment and have used brass sheet for the tank,but I can't see any reason not to have made it in steel.It certainly would have been a lot cheaper!
A member of the club to which I belong,recently completed a Class 2,with a steel tender tank.After every running session he dries out the inside of the tank with a hair drier (I'm not sure his missus approves or even knows!) He reports no problems with rusting.
I did read somewhere of a model engineer who coated the inside of his tender tank with a resin compound used for the restoration of old and rusty petrol tanks of vintage cars and motor bikes. |
IanT | 20/10/2009 15:04:59 |
2147 forum posts 222 photos | Dave,
A slightly different suggestion would be to make the tender from stainless steel. You can then use silicon to seal any riveted joints - or if you can TIG weld (or know someone who can) then even better, weld it up. I have a tender in stainless welded up as per the latter suggestion and it is a nice solid job.
Not sure where the material from my existing tender came from - but I have some very nice stainless steel 'kick plates' that came off the bottom of some office doors being replaced by a local company. They would certainly fit the bill for a 3 1/2" engine - and probably most 5" locos. |
