Plan wanted to construct a radius jig
Johan Crous | 25/09/2023 18:38:11 |
![]() 41 forum posts 1 photos | I am looking for a plan to construct a radius jig for the Harold Hall grinding table.
I would like to grind radiuses on HSS tool shafts and I would like to sharpen ball shaped milling cutters. I am thinking in the line of adding the Harold Hall end mill attachment on top of the radius jig or the other tool holeder to clamp HSS rods or shafts. A picture / photograph from where I can get an idea will also be appreciated. |
Martin Connelly | 25/09/2023 19:39:55 |
![]() 2549 forum posts 235 photos | There is at least one (short) video on Youtube showing ball end mill sharpening. https://youtube.com/shorts/aekWZX_JYLk May be helpful Martin C |
Johan Crous | 26/09/2023 14:21:51 |
![]() 41 forum posts 1 photos | Thank you. |
Diogenes | 26/09/2023 17:10:52 |
61 forum posts 6 photos | Hemingway Kits supply a kit for a simply-constructed radius grinding attachment kit for the 'Worden' tool & cutter grinder - here; ..worth looking at..? Hemingway Kits - Worden Mk III - Radius Grinding Attachment
noel shelley | 26/09/2023 19:29:18 |
2308 forum posts 33 photos | The worden radius attachment would really only radius tool ends not milling cutters without much alteration. You could copy the Clarkson attachment ? Noel. |
Johan Crous | 26/09/2023 19:57:09 |
![]() 41 forum posts 1 photos | Noel, I have done some crazy stuff in my life. I am sure I will think of something. I am now busy with an endmill jig that use a MT3 collet chuck ean therafter I will tackle this. I will keep you guys up to date. |
