Low profile finger clamp and plate
Greg Webb 1 | 22/09/2023 08:19:49 |
26 forum posts 2 photos | |
Diogenes | 22/09/2023 08:47:54 |
61 forum posts 6 photos | Neat piece of work.. |
Mike Hurley | 22/09/2023 10:17:38 |
530 forum posts 89 photos | Is this a commercial item rather than one made by you Greg ? The video seems to be of a quality that makes me think (including the plethora of adverts).
Greg Webb 1 | 22/09/2023 10:54:26 |
26 forum posts 2 photos | The item was designed and made by me this week. I have no control over the adverts & have refused any monetisation from Youtube. |
Mike Hurley | 22/09/2023 11:25:36 |
530 forum posts 89 photos | Nice job then Greg. Unfortunately these days I, along with many others, tend to be more and more suspicious of items being purported as one thing but actually are something else. So no offence intended. If you design and make other similar items do post details on here as these are just the sort of thing we like to see on the forum. All the best Mike |
Greg Webb 1 | 22/09/2023 11:40:33 |
26 forum posts 2 photos | Thanks Mike There are loads of unique engineering projects and tips on my Youtube channel. If you find anything useful or interesting let me know & I will share them on here or share them yourself if you want to. https://www.youtube.com/@machinists-shortcuts/videos
Michael Gilligan | 23/09/2023 17:03:26 |
![]() 23121 forum posts 1360 photos | Nice fixture, Greg … and well demonstrated too Just one naive question from me: What grinding wheel do you use? MichaelG. |
Greg Webb 1 | 24/09/2023 09:48:00 |
26 forum posts 2 photos | Posted by Michael Gilligan on 23/09/2023 17:03:26:
Nice fixture, Greg … and well demonstrated too Just one naive question from me: What grinding wheel do you use? MichaelG. I like to use a 46 grit for most things, especially when using the side of the wheel. I find it clogs less & cuts cooler. 46KV. |
Martin Johnson 1 | 24/09/2023 16:42:04 |
320 forum posts 1 photos | How did you machine the profile of the clamp base? Martin |
Greg Webb 1 | 25/09/2023 08:49:55 |
26 forum posts 2 photos | I machined the profile on a thicker piece of mild steel on a CNC mill. The excess thickness was then removed in two halves on a manual mill using the side of an endmill with the finished face against the fixed jaw. Then it was surface ground to thickness on both sides. |
Martin Johnson 1 | 25/09/2023 15:49:32 |
320 forum posts 1 photos | It was the return part of the "shaft" feature that had me foxed. It looks like quite a reach if you are machining that in steps. Martin |
Greg Webb 1 | 25/09/2023 16:28:05 |
26 forum posts 2 photos | Sorry Martin I am trying to post an image from underneath that should explain how it works but I can't. Any tips on pasting? |
Grindstone Cowboy | 25/09/2023 16:56:50 |
1160 forum posts 73 photos | FAQ on posting pictures can be found here. A bit complex, but hopefully will be sorted when the new forum software arrives. Links to https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1 Rob |
Greg Webb 1 | 25/09/2023 17:21:18 |
26 forum posts 2 photos | That was a bit of a faff to sort out, hopefully the new software arrives soon. So you can see the holes underneath for 5 - M4 cap head screws that go through the base & key then into tapped holes in the bar.
The elliptical hole is tapped for a sprung loaded ball grub screw that clicks into the vees on the stop shaft. This allows the stop shaft to rotate without losing its position as demonstrated in the video.
Martin Johnson 1 | 26/09/2023 14:13:17 |
320 forum posts 1 photos | Thanks for taking the time to post the photo. Everything clear now! Very nice design, well executed. Martin |
