bricky | 10/09/2023 16:31:08 |
627 forum posts 72 photos | I have wanted to build this since I retired 12 years ago.I got permition from the Museum for Lincolnshire Life to measure and photograph their engine.I was lucky to be given some drawings of the injector and pump.To decide on the scale I could make the engine I reduced the 4'6" flywheel to 3"scale and then made an injector at that scale to see if I could,I don't think I could make it smaller.But with a 13.5" flywheel it would be to big and the engine would be too heavy.I decided to build a Centaur and two of Brian Rupnows engines to get a feel for IC engines,I am now thinking of returning to the oil engine and wander if anyone can sugest a a way to make a smaller injector I am aware that it would not be to scale and 1.5" scale is now my aim.These engine were made in my hometown and my model engineering mentor actualy worked as a fitter on these before and after the first world war so I would like to be able to make one ,with advice from the members. Frank |
JasonB | 10/09/2023 16:38:41 |
![]() 25215 forum posts 3105 photos 1 articles | Have a word with Graham Corry of Alyn Foundry, he built a 1/4 scale one. Best to ask on Alyn's Facebook page, you will need to join. |
Roger B | 10/09/2023 20:08:53 |
![]() 244 forum posts 105 photos | As the Ackroyd engine only requires a low pressure fuel injector this should be feasible. I have made a selection of high pressure injectors (100 bar) for a full diesel. What size are you looking at? This is a 20cc full diesel, the injector body is 10mm square, the nozzle is 5mm diameter. https://youtu.be/nHYDfQaNw98
bricky | 11/09/2023 13:27:39 |
627 forum posts 72 photos | Thank you for replying Roger,I would like to make it in 1.5" scale or 2" scale but am unsure of how to make an injector small enough at these scales .Could you suggest one please. Frank |
Roger B | 11/09/2023 17:52:48 |
![]() 244 forum posts 105 photos | Hello Frank, I think we made contact on MEM a few years ago and you sent me a package of drawings. I have got them out and will see if I can suggest anything. This is unusual compared to more modern designs in that the spill valve is on the injector not on the pump. Did you ever try the 3" scale pump and injector? Keeping the hot bulb hot will also be a challenge at this scale. |
bricky | 11/09/2023 18:54:08 |
627 forum posts 72 photos | Hello Roger,I never tried to force fuel through the injector as the flywheel was to big for me to swing on the Myford.That is why I have come back to it as I was thinking smaller at 2" giving a 9" flywheel but having recieved a post from Graham Corrie at Alyn Foundry,he explained that he had problems with the injector at 3" scale.Unless an alternative can be had I can"t proceed.Thanks for any help you can come up with. Frank |
Roger B | 13/09/2023 19:50:56 |
![]() 244 forum posts 105 photos | I will write this as thinking out loud. If I am going away from what you want, please say, this is based on my experience. I have a working mushroom/poppet injector with a basic dimension for the valve of 1.4mm, 55 thou. This works with a full diesel with a water cooling. How this would work with a hot bulb I am not sure. The length can be reduced, it is designed to fit an existing cylinder head. I think that the spill valve on the injector will be too difficult, a dummy could be made for appearance. I would suggest a variable stroke injection pump. This could be partially hidden in the base and connected to the governor. Do you have your expected bore and stroke? I can then calculate a suitable injection pump bore. Springs need to be looked at. They need to be flat ended to avoid side pressures. I buy commercial springs, but they have a cost.
Roger B | 15/09/2023 20:07:46 |
![]() 244 forum posts 105 photos | Another option might be an open injector. I made this as a trial with a non return valve and a 0.2mm (8 thou) orifice. There was not enough atomisation for the diesel but it might work injecting into a vaporiser https://youtu.be/fS5owr5DIJQ?si=uHH1illsu5NXe2nC
Nigel McBurney 1 | 16/09/2023 10:31:55 |
![]() 1101 forum posts 3 photos | I restored and ran a 3 1/2 Hornsby oil engine for a long time,a big lump around 15 cwt, with twin flywheels ,the second flywheel was specified for electrical generation to smooth out the power strokes and improve governing. The Hornsby is not a diesel,the fuel is squirted at low pressure into the hotbulb on the induction stroke,the jet of fuel hits the far side of the bulb and cooks and vapourises,the subsequent compression and the heat in the hot bulb causes ignition.the governor arm controls the amount of fuel injected by increasing or decreasing the amount of travel of the needle valve in the injector,surplus oil flws back to the fuel tank. I saw Graham Corys engine running many years ago at the 1000 engine rally and was quite impressive,from memory i believe that the gas burner used to preheat the hot bulb had to be kept alight as the hot bulb could not retain it heat. Hornsby hot bulbs do vary internally some are plain others have ribs no doubt to suit various types of fuel (paraffin also known as lamp oil) Hornsbys also found that the small passage between the hot bulb and the cylinder was critical in its diameter, as this passage retained the rich mixture in the bulb until it mixed with fresh air on the compression stroke, and ignited before or around top dead centre there is no fixed timing,I think a lot of experimentation would be required to get the proportions of injector ,the hot bulb restriction know known as the Hornsby neck,compession which is very low in a full size engine, The Blackstone hot bulb engine used a timed disc in a tube mechanically timed to control when the fresh air on the compression stroke mixed with the rich mixture in the hot bulb, Blackstones did not use an injector they had a small oil resevoir adjacent to the hot bulb and sucked the fuel on the induction stroke into the hot bulb via a fixed jet, the disc valve stopped the subsequent rich fuel mixture getting into the cylinder,both Hornsby end Blackstone engines had timed air valves to allow fresh air to enter the cylinder on induction, now indicate how these engines can be difficult at times, after my Hornsby had run after about 3 days rallying carbon would build up on the injector jet and eventually deflect the jet of fuel so that it just dribbled into the hot bulb and did not hit the far side of the hot bulb and it would go sloer and stop,possibly due to running at slow dem speed and no work to do, now on my small Blackstones the timing valve can be critical or not needed, a friend demonstrated on his Blackstone that he could hold the the valve open and it would still run ok, I tried it and on one of mine it ran better with valve open and on another one I found that it was critical and if the adjuster on the valve was turned more than two flats of the nut it would stop within a few minutes. A lot of patience is requied with these early types of engines, and I think I would reluctant to go too small , |
