Myford CNC Conversion Kit - Tony Jeffree
Samuel Langley07/08/2023 23:16:19
3 forum posts
I've recently acquired a Myford ML7/Super 7 CNC conversion kit from Tony Jeffree's design. From what I can tell, it's partially completed and only needs the actual leadscrew modifications ('part 1' and Mach3 setup, of which the pulleys and belts are there. The cross slide pulley, leadscrew motor box, and controller are complete.
The CNC control box is from DIYCNC.co.uk and within is their Uniport V2 controller. I couldn't tell you much else about the full controller setup. There are two other parts contained, top right in the pictures, which are internal grinding spindles placed into a housing with bolt fixing locations on the Myford cross slide. My guess is that the original user was going to convert it into a 2 axis milling setup, well capable with this Uniport controller.
I was wondering if there's still demand for this sort of thing to be sold on as currently I've not got any interest in converting my ML7.
http://www.jeffree.co.uk/pages/ml7-cnc/part-1-files/myfordcncpt1.htm
http://www.jeffree.co.uk/pages/ml7-cnc/part-2-files/myfordcncpt2.htm
http://www.jeffree.co.uk/pages/ml7-cnc/part-3-files/myfordcncpt3.htm
http://www.jeffree.co.uk/pages/ml7-cnc/part-4-files/myfordcncpt4.htm
Ady108/08/2023 09:22:23
6137 forum posts
893 photos
Mach 3 is still about as far as I am aware, the steppers look like nema 23s 3amp jobs which are ok
a couple of controllers a power pack and a board all wired up and ready to go
Bound to be a few who would fight over it on ebay, especially since the build files are still available
Edited By Ady1 on 08/08/2023 09:24:48
Martin Connelly08/08/2023 12:41:52
2549 forum posts
235 photos
As long as you have 16bit computers that will run XP or Win10 and have a USB port I don't think Mach3 is going to disappear very fast. It has been around long enough to be stable and a lot of people are using it without problems. I know there are some people who would like to improve threading due to the single pulse per rev causing issues on low power lightweight machines, but if you have back gear, a drive train with plenty of mass and a sufficiently powerful motor there is no problem. I think people who converted machines with a speed control that reduced motor power were the ones having the biggest headache with threading.
Martin C
John Haine08/08/2023 13:38:41
5563 forum posts
322 photos
The Uniport is I think a parallel port BoB which also needs a USB connection to get +5v from the host. Mach3 needs a 32 bit processor to drive a parallel port, any 64 bit processor can only use a USB or Ethernet interface to a suitable motion controller. PCs with a parallel port must be pretty rare these days. However a USB motion controller such as the UC100 could be used with this to drive the parallel port input.
Mach 3 is OK but any new user would be well advised to use Mach4 or UCCNC or similar with a USB or Ethernet interface.  M3 is long in the tooth and unsupported for getting on for 10 years.
Edited By John Haine on 08/08/2023 13:40:45
duncan webster08/08/2023 15:03:50
5307 forum posts
83 photos
I've got a computer which has a parallel port. It is destined for the tip, so if anyone wants it come to north Cheshire and get it. Free, gratis and for nothing. If you really want to part with money a donation to the Sally Army. On security grounds I might take the hard drive out
Edited By duncan webster on 08/08/2023 15:04:33
Ady108/08/2023 18:00:18
6137 forum posts
893 photos
I think there are parallel port adapters about ported onto a usb connection
No guarantee that it will communicate 100% though, you have to buy and try
Edited By Ady1 on 08/08/2023 18:01:42
sam sokolik08/08/2023 18:12:12
126 forum posts
Posted by Ady1 on 08/08/2023 18:00:18:
usb to parallel port adaptors will not work in this situation...
sam
Ady108/08/2023 18:25:37
6137 forum posts
893 photos
Here's a fancy one, seems to be for mach 3
Martin of Wick08/08/2023 18:42:40
258 forum posts
11 photos
You can try to get a pukka UC100 USB to Parallel motion controller adapter if you want Mach 3 'big Button CNC' (for which you still have to pay a hefty licence fee). Find a reputable source of supply because it is said there are plenty substandard knockoffs about.
Or go down the Arduino UNO / CNC shield route wire up the drivers and PSU etc to it and use Grbl or any of the other free G code runners and run your machine off a laptop.
Much to my surprise, I managed to easily convert an old Chinese Mach 3 engraver/router with the arduino approach and I have no electronic knowledge whatsoever. Heaved all of the big boxes complete with parallel ports into a skip, never been so glad to see them go. Mind you, they were so old maybe they could have been flogged on line as 'vintage' post Turing computing equipment!
Edited By Martin of Wick on 08/08/2023 18:48:32
Martin of Wick08/08/2023 19:24:24
258 forum posts
11 photos
So to answer your actual question, I am sure there would be a demand for the mechanical parts and drivers for anyone wanting to convert an M7 to CNC.
A good thread on github with a modified Grbl but requiring an Arduino Mega - Doubt if a UNO would have enough capacity for the extra control a lathe requires.
Martin Connelly08/08/2023 19:38:49
2549 forum posts
235 photos
I said earlier 16 bit when I should have said 32 bit. I believe some 64 bit computers will not run Mach3
Martin C
Edited By Martin Connelly on 08/08/2023 19:39:08
John Haine08/08/2023 19:55:03
5563 forum posts
322 photos
Any 64 bit PC will run Mach3 with a USB or Ethernet motion controller, Win10 and 11.
GRBL has been used quite a few times on CNC lathes and I think there's a version called GRBLlathe. GRBL on an Arduino or something more powerful and ARM-based should be an interesting approach for a motion controller for M3 but one would need a Mach3 "plugin" that would involve getting the API details from Newfangled Solutions. They don't really want people using Mach3 any more (though they are pleased to sell it).
Samuel Langley08/08/2023 22:08:59
3 forum posts
Thanks all for your replies!
I'll likely be listing it on eBay soon, along with a link to this thread with all this amazing information.
Michael Callaghan10/08/2023 12:12:05
173 forum posts
7 photos
I have been using mach3 with usb connection for years. It’s not the mach3 program that stops people using usb it’s the breakout board they use. I have converted two lathes to run on Mach 3 it’s simple enough. The only pain I had was working out the steps per revolution etc, as it’s not automatic on the Mach 3 turn program, why I don’t know.
John Haine10/08/2023 12:21:00
5563 forum posts
322 photos
Posted by Michael Callaghan on 10/08/2023 12:12:05:
Would be helpful if you could specify which BoB you use?
Michael Callaghan10/08/2023 13:13:49
173 forum posts
7 photos
I use a CS-LABS Bob, however there are a few very good cheaper bobs on Amazon or eBay that work very well.
John Haine10/08/2023 14:17:44
5563 forum posts
322 photos
Thanks, so a combined motion controller and BoB.
Michael Callaghan10/08/2023 15:09:35
173 forum posts
7 photos
The CS-LABS unit is, the cheaper bobs on eBay not. However I have found both very easy to set up and use.
Samuel Langley20/08/2023 09:08:01
3 forum posts
Hi all,
I have listed this kit on eBay if anyone who comes across this thread is interested.
https://www.ebay.co.uk/itm/266377098611
