Antony Harding | 30/07/2023 15:21:01 |
27 forum posts 7 photos | Hi All, Can you kinldy help on directing me on whats Oil / Grease I can buy what are the equivalent to the old sepc oils / greases as noted in the manuals (Beaver Mill & Smart & Brown Lathe) MILLER - Shell Vitrea 33 - Shell Macoma 75 - Alvania 2 LATHE - Mobil DTE Light Oil - Castrol XL On both machines there are grease nipples, is there a grease gun that you can buy whcih is slef filling? i.e that does't use the grease catridge tubes?
Michael Gilligan | 30/07/2023 15:29:13 |
![]() 23121 forum posts 1360 photos | Posted by Antony Harding on 30/07/2023 15:21:01:
[…] On both machines there are grease nipples, is there a grease gun that you can buy whcih is slef filling? i.e that does't use the grease catridge tubes?
https://lubricantssw.co.uk/product/wanner-one-hand-grease-gun/ … I’ve had mine for decades MichaelG. |
Andrew Johnston | 30/07/2023 16:17:28 |
![]() 7061 forum posts 719 photos | Just because it looks like a grease nipple doesn't mean it is for grease - RTM. Andrew |
Dave Halford | 30/07/2023 16:23:04 |
2536 forum posts 24 photos | Castrol XL was multigrade engine oil from 1900 and frozen to death still available on ebay at £15 per L PS you can refill cartridge grease guns Edited By Dave Halford on 30/07/2023 16:24:29 |
Michael Gilligan | 30/07/2023 16:32:00 |
![]() 23121 forum posts 1360 photos | See here for most of what I know about Vitrea: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=171223&p=2 MichaelG. |
Howard Lewis | 30/07/2023 21:17:42 |
7227 forum posts 21 photos | The machine may have grease nipples, but in some cases, putting grease through them can be BAD news. The grease will solidify, so that the oilway is blocked and the bearing gets no lubrication. It may well be that the correct lubricant for that particular point should be oil. If you need an oil gun, I can recommend a Rielang, may seem costly, but does not leak and works at almost any angle. HTH Howard |
Antony Harding | 31/07/2023 18:23:14 |
27 forum posts 7 photos | Hi all, many thanks for the help and info.... its got me on the right track. |
