Loseby's Isochronal Spring
david bennett 823/07/2023 16:50:54
245 forum posts
19 photos
Has anyone noticed this? I came across it in my pdf copy of Grimthorpe's Clocks Watches and Bells on pages 63/4. There is a very brief description. It seems to be a very simple single loop of spring wire loosely embracing the pendulum rod so that over-impulsing would cause the rod to stretch the loop. This device was exhibited in 1851 and at first the Astromer Royal said it worked. Then Grimthorpe intervened on the grounds that escapement errors had the opposite effect. The AR did some more experiments, then dismissed the spring.
Now that the trend is towards removing the escapement and it's errors, is it time to re-visit this? Does anyone have any detail of it's construction? If it is any use it could easily be retro-fitted to any pendulum.
dave8
Michael Gilligan23/07/2023 17:25:56
23121 forum posts
1360 photos
Thanks for the reference yes
I felt sure that I had a PDF on the iPad, in GoodReader … but couldn’t find it crying 2
Downloading it again revealed the file name and all is now well.
John Haine23/07/2023 18:03:26
5563 forum posts
322 photos
This kind of arrangement has been invented more than once to correct for circular deviation.
david bennett 823/07/2023 18:39:47
245 forum posts
19 photos
Posted by John Haine on 23/07/2023 18:03:26:
John, after much unsuccessful searching, can I ask if you have any references?
dave8
Michael Gilligan23/07/2023 21:18:05
23121 forum posts
1360 photos
Brief mention of Loseby’s device here: **LINK**
http://www.thetimeworkshop.uk/loseby-reasearch/
david bennett 823/07/2023 21:57:24
245 forum posts
19 photos
Thanks Michael.Yes, I had seen that sad story. The British Museum suggested a couple of books. Nothing in Brittans, I dont have access to the Loomes clockmakers list.
dave8
Michael Gilligan23/07/2023 22:59:58
23121 forum posts
1360 photos
One, somewhat confusing, image here: **LINK**
https://www.bridgemanimages.com/en/search?filter_text=1851%20great%20exhibition%20loseby’s&filter_group=all&filter_region=GBR&sort=best_relevance
david bennett 824/07/2023 02:29:32
245 forum posts
19 photos
Michael, thanks. The link didn't work at first until I re-entered the search with inverted commas. I take it it's the engraving of a mercury compensated pendulum with what could be the spring?
dave8
Michael Gilligan24/07/2023 04:21:28
23121 forum posts
1360 photos
Indeed, Dave yes
Sorry … I hadn’t noticed the ascii error …
david bennett 824/07/2023 04:33:52
245 forum posts
19 photos
Thats ok. I have found it with explanation on internet archive. Its " The practical mechanics journal" vol 5 dated 1853. The explanation is not much more than can be guessed at from your pic.
dave8
Edited By david bennett 8 on 24/07/2023 04:34:18
david bennett 824/07/2023 13:41:21
245 forum posts
19 photos
Posted by david bennett 8 on 24/07/2023 04:33:52:
ps - page31
dave8
John Haine24/07/2023 14:14:33
5563 forum posts
322 photos
David,any chance you could post an image of the relevant page or a direct link please?
david bennett 824/07/2023 18:28:13
245 forum posts
19 photos
John, willl try -the file is too large
dave8
david bennett 824/07/2023 19:24:21
245 forum posts
19 photos
https://books.google.co.uk/books?id=B9pQAAAAYAAJ
Hi John, see if this works
dave8
david bennett 825/07/2023 14:01:25
245 forum posts
19 photos
https://books.google.co.uk/books?id=nDxWAAAAcAAJ
John, have just found this better account of Loseby's compensator
dave8
Edited By david bennett 8 on 25/07/2023 14:26:30
Michael Gilligan25/07/2023 14:20:22
23121 forum posts
1360 photos
Well done, Sir
… tucked away quietly after his masterly ‘secondary compensation’ of the Chronometer Balance
Edited By Michael Gilligan on 25/07/2023 14:25:43
John Haine25/07/2023 18:52:31
5563 forum posts
322 photos
Thanks Michael and Dave. Similar in principle to methods proposed by others except Loseby was first and certified by Airy no less! I will try to dig out the other references I've seen.
John Haine26/07/2023 12:15:28
5563 forum posts
322 photos
The other key reference on this is by Bush and Jackson "Correction of spherical error of a pendulum" in
Journal of the Franklin Institute
Volume 252, Issue 6, December 1951, Pages 463-467
alas only available if you pay or have institutional access. Vannevar Bush was an eminent US science maven in WW2 and after who played a major role in things like early computers etc. Also interested in clocks and there are a couple of articles in Scientific American describing their experiments dating from the early 1960s. The article above has a reference to Loseby but he only had the rather negative Grimthorpe reference and hadn't seen the Practical Mechanics stuff and the test report by Airy. The scheme used a tension spring pulling downward on a point on the pendulum, the other end being held vertically below the point of suspension. As the pendulum swings the spring is slightly stretched and the geometry can be designed to provide an additional restoring force proportional to the cube of the angle that can cancel the cubic term of the sinusoidal restoring force. In practice they used a cantilever leaf spring at right angles to the pendulum with a thin wire connecting it to the pendulum rod. Good results are reported, I haven't compared them with Airy's measurement yet.
As far as I can see Loseby's spring creates the cubic dependency through its shape and from my brief look at the description he doesn't say what this has to be mathematically. By contrast Bush only assumes that the spring is linear (a good approximation for small extensions) and the cubic term comes from the geometry.
John Haine28/07/2023 08:51:47
5563 forum posts
322 photos
Michael was asking for more details of my claim of other mentions of a similar technique.
  • Loseby's approach actually only applies the correcting force over a small part of the arc on one side.
  • Bush/Jackson aim to exactly correct for the cubic terms at least for small deflections.
  • The Bulle clock included a coil spring arranged in a very similar way to Bush's to keep period constant as battery voltage declined, in the early 20th century.
  • David Robertson described the theory of the Bush type compensator in 1929 in one of his classic HJ articles.
  • IIRC Peter Hastings described a scheme a bit like Loseby's in HJ a few years ago.
Michael Gilligan28/07/2023 09:16:50
23121 forum posts
1360 photos
Posted by John Haine on 28/07/2023 08:51:47:
dont know really ? … I thought it was dave8
