Prop size for given cc
bernard towers | 22/07/2023 12:12:56 |
1221 forum posts 161 photos | I am presently working my way through a Humbug 1.5 glow motor but have not found any reference to prop size, anyone got any ideas or is there a table available for this sort of thing. Where are you Tug? |
Howard Lewis | 22/07/2023 12:20:03 |
7227 forum posts 21 photos | Prop size and pitch will be determined by the speed and power of the engine. A low speed engine of the same power, will run a coarser pitch prop of the same diameter, than a high speed motor. |
Clive Brown 1 | 22/07/2023 12:57:24 |
1050 forum posts 56 photos | I wouldn't think the precise size is hugely critical, but ISTR from my aero-modelling days that a 1.5cc engine would take a prop of 7" to 8" dia and around 5" pitch. The larger diameter might give better starting dur to flywheel effect and also keep the revs down on a new engine. I don't think that you'll do any harm at around those sizes. |
DiogenesII | 22/07/2023 13:08:42 |
859 forum posts 268 photos | When I built my Boll 1.8 ci, I used a (-actually, I'll have to check - oops), I think it would be a fairly 'safe' place to start for initial set-up with the Humbug - but happily defer to those with greater experience, I'm a rank beginner. I think at least it would give you a sense of 'what it wants' Edit - just seen Clive's post - better advice, maybe.. Edited By DiogenesII on 22/07/2023 13:10:38 Edited By DiogenesII on 22/07/2023 13:16:51 |
Ramon Wilson | 22/07/2023 13:18:56 |
![]() 1655 forum posts 617 photos | Hi Bernard - still here in Beccles Clive's advice is sound - early runs on say a 8 x 4 and a 7 x 4 for general running will be fine. Keeping the pitch at 4" or below allows the engine to rev without being loaded. You could use a 6" pitch on bench running but that would usually be much better suited to flying situations. I very rarely (bench) run my engines on 6" pitch props for that reason I have a FROG Talisman control liner with a Frog 150 in it. So nippy it's getting difficult to handle these days so it flies on a 7 x 4 prop to slow it down a bit Getting small props may prove difficult - so much these days are aimed at electric motors but Leeds Model Shop might be a good start. Just to get you in the mood here's a new model - it's an enlarged 30" span KK Ranger with an OS 20FP glo motor converted to diesel. See you at Lowmex?
Best - Tug |
geoff warner 1 | 22/07/2023 13:21:50 |
12 forum posts | these questions take me back a few years i had a mills 1.3 engine but could not start it as i had a small 6 inch nylon prop on the mills i was advised it was too small and not heavy enough and was given an 8 inch wooden prop and it started and ran straight away. |
bernard towers | 22/07/2023 13:55:57 |
1221 forum posts 161 photos | Yes I’ll be there Tug. And thanks everyone for the input, I will look into getting a couple. Edited By bernard towers on 22/07/2023 13:57:32 |
Ramon Wilson | 22/07/2023 18:16:00 |
![]() 1655 forum posts 617 photos | Here you go Bernard - these Graupner props from Leeds Model shop will be ideal and reasonably priced too. **LINK** The 7 and 8" dia are on the second page LMS are very efficient on dispatch so can recommend them Edited By Ramon Wilson on 22/07/2023 18:17:32 |
