Sonic Escape | 22/06/2023 22:41:58 |
![]() 194 forum posts 5 photos | Last winter I was looking for a milling machine. And in the end I bought a lathe I wasn't planning to buy a milling machine now. I have enough fun with the lathe. But at some point in the future I'm sure I will considering to buy a new one. Something up to 2000euro and in 130-200kg range. I'm not sure if this old machine is a good deal. For sure it is more rigid, it has 800kg. But a new one is ... new. Also in the second image I don't understand why the top part can extend to the left mote than the width of the table? And what is the table in the last picture? |
Huub | 22/06/2023 22:59:08 |
220 forum posts 20 photos | A milling machine, standing in the garden (for some time) in working order that can't be tested, is a gamble. Such a heavy machine isn't a walk in the park to take apart. Here in the Netherlands, these type of machines are for sale quit often so I can wait for a machine that can be tested.
Nigel Graham 2 | 22/06/2023 23:26:26 |
3293 forum posts 112 photos | Assuming the ways and lead-screws are not too badly worn, that milling-machine looks as if it could be a very good and useful, but power-hungry, machine. It seems to have been cared for. In some respects the motor's condition is less important because that can be replaced relatively easily (though not cheaply) with a modern 3-ph motor and VFD.
The extension of the "top part" beyond the table is to allow it to support the horizontal-milling arbor without encroaching on the table area. There should be with this machine, that arbor and its supporting drop-bracket, which would to have dovetails to fit those on the underside of the ram. What I have just noticed further, is that the head is in two parts: the ram is carried on a lower part that itself can be moved back and forth. I am guessing this is allied to using the machine with.... .... that separate table. As I believe it is, to fit on the knee so its working surface is vertical, rather like a super-sized angle-plate. Looking at the other photos, it does seem the table on there at present is carried on a separate slide so can be swapped. Looking back again, there seems no in-out travel for the table itself. Instead the head is moved. I am not sure how that affects milling round an outline like a rectangle, but I've a suspicion the machine's primary use is as a horizontal mill, where all the cutting is longitudinal. I mentioned "the" motor. It might have more than one - the spindles, obviously, but others for power feed and table rise-&-fall. . You'd need an overhead hoist or other handling equipment, perhaps a dedicated trolley, to swap the tables safely. I looked carefully but could not see a maker's name on it, but I think Deckel and Aciera are two makes with this interchangeable table system.. Try to identify it then see what Tony Griffith's lathes.co site has to say about it. |
Sonic Escape | 22/06/2023 23:56:42 |
![]() 194 forum posts 5 photos | What caught my attention is that the table has no scratch. So maybe it wasn't used too much. I have no problem to fix the machine, I actually think that would be interesting. But I'm aware that are things that can't be fixed. Or it is simply too expensive.
Bazyle | 23/06/2023 00:05:05 |
![]() 6956 forum posts 229 photos | You know it's a Deckel right? Highly prized machine if it can be restored. |
Nigel Graham 2 | 23/06/2023 00:20:54 |
3293 forum posts 112 photos | " Tall workpieces? " Yes, but more particularly so large parts can be machined on two or more faces at right angles to each other. E.g. something like a large worm-drive gearbox needing two multi-diameter bores to intersect very accurately; and too large to mount on an angle-plate on the table in the conventional way. I don't know the Deckel machines in detail but it might have a knee drive arranged as a full precision power-feed, not simply as a way of raising and lowering the heavy table without wearing the operator out. |
William S | 23/06/2023 00:37:40 |
![]() 80 forum posts 335 photos | Not a Deckel but a Theil 158 **LINK** same layout as the Deckel just a tad bigger, Stefan gotteswinter on YouTube has a Deckel and demonstrates it’s versatility, in my opinion I would prefer that over a new mill any day of the week. I hope that helps William |
Sonic Escape | 23/06/2023 06:00:57 |
![]() 194 forum posts 5 photos | Indeed it looks like a Thiel 158! Or most likely a Romanian copy of it. I didn't saw the Thiel logo on the spindle. The first models were made with a custom spindle but the later ones were using standard MT5. It is a pity that the seller doesn't know this details. Edited By Sonic Escape on 23/06/2023 06:02:27 |
Sonic Escape | 23/06/2023 07:09:51 |
![]() 194 forum posts 5 photos | I asked the seller to send more photos and surprise, I think there is also a horizontal milling attachment. Or at least a part of it? Is that thing under the table. This would explain why the top of the machine can extend so far. That is also what Nigel Graham 2 suggested. Edited By Sonic Escape on 23/06/2023 07:11:30 Edited By Sonic Escape on 23/06/2023 07:19:54 |
jaCK Hobson | 23/06/2023 07:31:44 |
383 forum posts 101 photos | It's chalk and cheez.. but still tricky to make a decision! Do you want to draw, or eat? Both If you are sure you can cope with handling a big machine, now and later, then big machines have many advantages in use. Even so, a good small new mill might still be useful in the future. So they are not necessarily mutually exclusive. A good, new, small mill can easily cost more than a much better, old, big mill. In the end I was too daunted with the idea of moving such a big machine and dedicating such are large area to it's siting. Usually I don't regret it. But old iron might not 'just' be a bit worn. With all the power feeds and multiple motors on some of them, essential features (like fine height adjustment via quill rather than table) might not work and could be difficult to restore. To be sure, you have to know how to work every part of the machine and have access.
Chris Evans 6 | 23/06/2023 07:55:32 |
![]() 2156 forum posts | For hobby use these old style mills lack spindle speed for small cutters. |
Sonic Escape | 23/06/2023 08:02:01 |
![]() 194 forum posts 5 photos | Yes, is not an easy decision. The fact that this old machine is more complex that a small new one is a risk but it also makes it more interesting. I start to think that I could do something with all that metal anyway. At least if the ways are ok. That is the only thing I don't think can be fixed. |
Dave Wootton | 23/06/2023 08:09:34 |
505 forum posts 99 photos | I've owned a Thiel 158, it was an excellent machine for the use I needed it for, to cut fairly chunky gears on, and indeed was an really well built and versatile machine. I bought it very cheaply as it had been standing for years, inside but not in ideal conditions, and although in good order there were a few problems to be overcome. The machine was bought for the specific purpose of doing some heavy milling and gear cutting for a traction engine project, which it did very well. It was then sold on to a friend who still uses it for traction engine building. I'm not trying to discourage, but these and the clones ( which I think this is) which follow the basic design quite closely, are a fairly complex machine, I had to replace all the oil seals in the feed and main gearboxes, which entailed a lot of dismantling and was very time consuming. The original main motor contains an automatic cone brake as used in small cranes, and will not run on a standard phase converter without a pilot motor. If you are looking for a fairly long term project then after some hard work you would have a superb heavy duty milling machine, power feed in all directions. I'm used to working on machine tools and found it a surprisingly long job and I was not fully resoring it just making it leak free ( every seal on the machine had turned rock hard with age) and suitable for the work in hand. Not as I say trying to discourage, just pointing out that this is quite a major undertaking to do properly, it's a heavy thing, do you want a mill or a major project?. As someone stated above the condition is a bit of a gamble so I would not pay too much for it if you decide to go for it. Mine was a few hundred quid so not a major risk financially, but there was a fair amount of time had to be invested in it. There was a chap making replacement spindles for the vertical heads to convert to 40 int from the I think 5mt original ( might be 4 mt, can't remember!) mine had already been done. If you do buy it you can always PM me as there are some traps for the unwary that I can vaguely still remember! Dave
Sonic Escape | 23/06/2023 08:16:26 |
![]() 194 forum posts 5 photos | Posted by Dave Wootton on 23/06/2023 08:09:34:
Thank you Dave, this was helpful. |
Dave Wootton | 23/06/2023 08:49:14 |
505 forum posts 99 photos | Been racking my brain to remember the make of the motor with inbuilt brake, it's a Demag and has a cone clutch on the end of the motor. The motor shaft is given some end float and is sprung loaded and when the motor is energised the rotor moves in towards the motor and away from the brake housing. the reverse happens when the power is switched off stopping the spindle very rapidly. Great feature that caused some consternation at first thinking the motor was siezed! Dave
Dave Wootton | 23/06/2023 10:14:10 |
505 forum posts 99 photos | Me again! Just noticed that in the classifieds under the heading various there is in the list an Alexander master toolmaker mill for sale, the smaller version of this style of machine, and a copy of the Deckel. Stated as being well tooled and running on an inverter. Might be of interest to you, I've bought something from Chris the seller in the past and he is a nice chap to deal with and very knowledgeable. Dave |
Sonic Escape | 23/06/2023 10:30:45 |
![]() 194 forum posts 5 photos | Posted by Dave Wootton on 23/06/2023 10:14:10:
Me again! Just noticed that in the classifieds under the heading various there is in the list an Alexander master toolmaker mill for sale, the smaller version of this style of machine, and a copy of the Deckel. Stated as being well tooled and running on an inverter. Might be of interest to you, I've bought something from Chris the seller in the past and he is a nice chap to deal with and very knowledgeable. Dave I live in Romania. I'm just infiltrating here Edited By Sonic Escape on 23/06/2023 10:32:25 |
Dave Wootton | 23/06/2023 11:20:52 |
505 forum posts 99 photos | That does put a whole new spin on things!!! Collection could prove difficult and expensive. Are machines readily available in Romania? just out of interest, I was wondering whether the Chinese machines are available as easily as here, and if there was a market in ex industrial machinery. Always interested in how other countries do things. My son is a professional musician and regularly visits Romania and says it is a spectacularly beautiful place. I'm sure you are aware that this could have a marked bearing on the desirability of the pictured mill. Dave |
Chris Gunn | 23/06/2023 12:03:35 |
459 forum posts 28 photos | Sonic, there looks to be several very expensive accessories with the machine, so maybe worth a gamble if the price is right. If the motor is in the base it may be relatively easy to change it for an up to date motor and then fit a VFD. Chris Gunn |
Nigel McBurney 1 | 23/06/2023 12:05:18 |
![]() 1101 forum posts 3 photos | I have worked on a Deckel,and for accuracy they cannot be beaten,if its a copy it should still be a good machine,the tables look good very few marks,I found those multi slot tables so much better than long narrow tables plenty of space for clamping work.
