Unimat 3 carrier rigidity problem
Julius Henry Marx16/06/2023 22:32:50
113 forum posts
52 photos
Hello:
Seeing that the topic that originated this post has been solved, I have split it to continue here in order to address a different but closely related Unimat 3 problem.
Originally started to find a solution to a severe rigidity problem I was having, the idea was to replace the existing lift strips and the post was a query about the suitability of using hard aluminium for making a new set.
Then, at one point (11/06/23 02:08:13), member Kiwi Bloke posted this:
"Some years ago, I obtained an apparently unworn, probably barely used, U3, in a grubby, but not rusted condition. After a complete strip-down and clean, I tried to turn some approx. 3mm dia. MS stock. It was hopeless! It transpired that the mating surfaces of the underside of the saddle held the 'lift strips' a tiny bit away from their ways on the bed, so the saddle could move vertically. Some careful blueing, and needle-file work on the saddle soon had them snug. Problem solved. Check yours!"
What Kiwi Bloke was writing about was exactly my experience, so I immediately started stripping my U3 to check.
After you have done it the number of times I have (more than a dozen) it sort of becomes easy to do. 8^°
Provided you don't lose any parts but please don't ask.
The general process was more or less as follows:
  • total stripdown to bare bed + clean/wipe down.
  • check bed for warping on a 300mm x 500mm x 8mm plate glass.   -> passed
  • check ways for warping with the plate on top of ways. -> passed
  • check surface of hardwood mounting blocks are on same plane. -> corrected
  • reassemble and check no warping had been introduced. -> passed
  • mount on its board and check for previous rigidity problems. -> failed ie: same problem as before
Once finished with all that, I concluded that I could (?) rule out other sources of trouble. Time will tell but for now this was a welcome relief.
I then checked to see what was going on with the lift strips.
Moving / lifting the carriage enabled me to visually confirm that the problem was exactly the same as the one described by Kiwi Bloke in his post: the properly tightened lift strips were not making proper contact with the guides under the ways.
But here's the thing: before deciding to purchase the U3 and then after taking it apart for the first time, I spent countless hours scouring the web for anything related to drawbacks, problems, fixes, workarounds, useful modifications, etc. and while I cannot possibly claim to have read everything out there, I can confidently say that I never came across any reference to the problem Kiwi Bloke posted about.
Maybe it got lost when some user group shut down or the hosting service went down, no way to know now, but here it is.
For that very reason I was dead set on documenting the work on the lift plates' mounting surfaces but my digital camera decided not to help by ignoring the SD card inside the slot and insisting there was nothing there.
But I digress.
Once I had a clear idea of the (very) slight amount of material that had to be removed, I decided to use an old and worn down 6"x5/8" flat file to remove the excess material, a tiny little bit each time.
Here is a photo showing what Kiwi Bloke wrote about:
The red line coincides with the surface underneath the front way where the lift strip has to tightened against and the green line coincides with the surface to which the lift strip is tightened.
Due to a bad photograph, a shaky hand/mouse using mouse/MSPaint and a number of optical effects I cannot recall how to explain, the difference observed between the lines is really much less that what it appears to be.
But it boils down to this:
If both lines are at the same level, the lift strip will not touch the surface underneath the way and the carriage will move upwards, so the green line has to be above the red line.
The same thing obviously applies to both lift strips.
After a countless number of iterations ie: filing the surfaces, mounting the carriage, tightening the lift strips, checking the carriage movement and then unmounting it again to file off some more material, the stars finally started to line up.
And the problem seems to have been fixed. Although promising, the jury is still deliberating.
As I will be replacing the ca. 1980 OEM lift strips with a new set made from 5/8"x5/32" brass, there will be photos to show what was done along with a description on how it was done to be kept here at ME for other U3 owners looking for a solution.
I don't want to end this post without first tipping my hat to Kiwi Bloke for graciously posting both about the problem and a proven solution.
Unless something else comes up, I hope to be posting further comments and a couple of photographs in a few days's time.
Best,
JHM
Edited By Julius Henry Marx on 16/06/2023 22:44:51
Michael Gilligan17/06/2023 08:01:28
23121 forum posts
1360 photos
Julius
Whilst fully accepting the difficulty of photographing this arrangement … I find your image rather worrying: It appears that there is a gap on the right-hand [as viewed] slope of the prismatic bearing surface !
Grateful if you could confirm that this is a mere illusion.
… if it was real, you would have a lot of work to do !
Hopper17/06/2023 09:20:35
7881 forum posts
397 photos
I wondered about that too. But assumed it was a trick of the light. If not, then yes, something definitely to be addressed.
Kiwi Bloke17/06/2023 11:07:03
912 forum posts
Well, thanks for the thanks Julius. It's always nice when there's evidence that one's posting has helped (or even been read and understood...).
I wouldn't bother changing the strips. Just flatten them with a fine file. Beware abrasive paper, in case grit gets embedded. I would imagine that the material was chosen so that the strips could be tightened down in a loaded condition, without too much worry about seizing because of poor Not many people would boast about their expensive disappointment, would they?lubrication.
It does seem ironic that it's not always easy to find complaints about machines' shortcomings, and grumbles about machine design, manufacture and performance before one buys a disappointment. (See also Ford Ecoboom thread!) Perhaps few people like to admit even to themselves that they've bought a lemon. However, once there's a trickle of discontent published, it's sometimes followed by a torrent...
One could completely fill the forum with fully-justified gripes about Myfords, Emcos, Cowells, Fobcos and other 'well-respected' makes, but their owners seem to prefer to keep quiet - although freely making disparaging remarks about far eastern built-down-to-a-price-and-down-to-an-even-lower-quality machines. Not many people would boast about their expensive disappointment, would they? I'm impressed by the number of Cowells lathes that turn up for sale in apparently almost-unused condition. I wonder why. I could fill pages with my criticisms of the machine (if anyone's interested)...
Sadly, there are plenty of areas of design and manufacturing weakness in Unimat 3 (and other Emco) machines: the U3 saddle 'lift strip' arrangement and the vertical quill's bearings have been discussed here, and Graham Meek and others have worked wonders on various improvements. With suitable attention, U3s can be made into useful, although very limited machines. But 'fresh out of the box', they are a gamble.
Julius Henry Marx17/06/2023 12:59:11
113 forum posts
52 photos
Hello:
Posted by Michael Gilligan on 17/06/2023 08:01:28:
... appears that there is a gap ...
Posted by Hopper on 17/06/2023 09:20:35:
... assumed it was a trick of the light.
Quite so ...
There does appear to be a gap and just as worried as you, rushed to look at the carrier again to check.
But no, it is indeed a trick of sorts.
First, there was (not any more) a very slight burr casting a shadow, in turn made to look worse by having magnified the original image to try to get more detail of the problem at hand.
And then there is what seems to be a very slight deformation of the aluminium casting, most probably produced while machining the underside of the carrier.
So, fortunately there is no gap, at least not one that I can detect or measure at the moment.
Thanks for mentioning it.
Best,
JHM
Edited By Julius Henry Marx on 17/06/2023 13:13:44
Michael Gilligan17/06/2023 13:15:49
23121 forum posts
1360 photos
Thanks for checking … I am relieved, but probably not as much as you are !!
Julius Henry Marx17/06/2023 13:54:37
113 forum posts
52 photos
Hello:
Posted by Kiwi Bloke on 17/06/2023 11:07:03:
... thanks for the thanks Julius.
You're welcome.
... nice when there's evidence that one's posting ...
Your post has been very helpful and most importantly, it will be also helpful to others in the same pickle. Because that's what it is all about, no? ie: sharing and spreading knowledge.
... wouldn't bother changing the strips.
Ahh ...
I've already made the new set, just need drilling and finishing but I will keep both your advise and the OEM strips. Worst case scenario, I'll can always go back to the plastic ones.
As the brass stock I purchased is 5/8" (15.9mm), I have kept the new strips at that width so as to avoid having to machine them down to 13mm and also a bit longer, 49mm instead of 47mm.
This new size comes in handy as the slightly larger surface will cover a good part of those cost-cutting voids between the strips and the carrier body (swarf does find its way in there!) and help with an experiment I want to run by placing small pads of SAE10 oil soaked felt in them, hopefully helping with the strips' lubrication and denying the swarf a place to reside in.
... not always easy to find complaints ... | ... before one buys a disappointment.
Yes, like you point out, no one likes or is willing to accept that they have purchased a lemon. Much less if said lemon was dry and very expensive.
... plenty of areas of design and manufacturing weakness in Unimat 3 ... | ... can be made into useful, although very limited machines.
Yes, but now it is my U3 so I have to / will make the best of it by (hopefully) manage to get it to work as intended/reported by everything I read about it.
Thanks for your input.
Best,
JHM
Julius Henry Marx17/06/2023 14:07:20
113 forum posts
52 photos
Hello:
Posted by Michael Gilligan on 17/06/2023 13:15:49:
You're welcome.
... relieved, but probably not as much ...
Yes, I am quite relieved that there is no gap I can (at least for now) detect / measure.
Once the new stips are in place and I can run a few tests to check how they are working ie: if they seize, etc. I will go about the procedure you posted in my previous thread and see how the carriage is behaving with respect to the ways.
We'll see then if any painting, scraping / diamond disking is needed.
The new screw nut I made for the cross slide seems to be working well enough but the backlash inherent to the M8*1 LH thread is still there as I have not yet practised the slit or drilled for the small screws to be able to make the necessary adjustments.
Thanks a lot for your input.
Best,
JHM
Edited By Julius Henry Marx on 17/06/2023 14:09:01
Michael Gilligan17/06/2023 15:12:18
23121 forum posts
1360 photos
Posted by Julius Henry Marx on 17/06/2023 12:59:11:
dont know
Now there’s a thing for the wise folks on this forum to ponder [preferably on your other thread]
Why do they consider a good Aluminium alloy unsuitable for the strips, when the ‘carrier’ is an ‘aluminium casting’ ?
Julius Henry Marx17/06/2023 17:31:45
113 forum posts
52 photos
Hello:
Posted by Michael Gilligan on 17/06/2023 15:12:18:.
... a thing for the wise folks on this forum to ponder ...
I'm just the beginner who had doubts about the use of aluminium alloy for the lift strips in the first place as the purveyor's recommendation (from the start) did not match what I had seen (steel, cast iron, brass, bronze, Delrin type plastics and Teflon) which is why I asked.
Reading the replies, the lack of precedent in the use of aluminium alloy gibs (and other uses such as bearings) plus the possibility of aluminium oxide working against the cast steel ways made the decision clear for me.
But as you well point out, the carrier is made from aluminium alloy.
So I think yours is a valid question that would, should there be enough members interested, merit a another, different thread. eg: suitable materials for making gibs, lift strips and similar parts.
Personally, I don't think that the carrier being made from an aluminium alloy can justify the use of that same material for the lift strips.
Like I have pointed out, I'm just the beginner with the question.
But should you ask me, my answer would be that the use of an aluminium alloy to manufacture the carriage was, along with its defective design, the worst manufacturing decision Emco could have made with the Unimat 3.
JHM
Edited By Julius Henry Marx on 17/06/2023 17:33:17
Dave S17/06/2023 21:28:27
433 forum posts
95 photos
Pretty sure the saddle is not "aluminium". I think it's mazac or similar alloy.
The headstock and tailstock castings are also the same mazac type alloy.
Edited By Dave S on 17/06/2023 21:37:17
Michael Gilligan17/06/2023 21:39:07
23121 forum posts
1360 photos
Plenty of choices there, Dave : **LINK**
https://en.wikipedia.org/wiki/Zamak
Whilst we’re guessing … do you know if any of them have particular merit as a bearing ?
Edit: __ I can find no hints here: https://xometry.eu/en/die-casting-materials-selection-guide/
Edit: __ but I have found some excellent photos of a used casting, here:
 https://www.thetoolsquirrel.co.uk/ourshop/prod_7617822-Emco-Lathe-Spares-Emco-Unimat-3-Bed-Slide.html
with visible wear marks on the prismatic bearing-surfaces.
Edited By Michael Gilligan on 17/06/2023 22:02:53
Julius Henry Marx17/06/2023 23:24:52
113 forum posts
52 photos
Hello:
Almost there ...
Posted by Julius Henry Marx on 17/06/2023 13:54:37:
... already made the new set, just need drilling and finishing ...
Decided to start with the finishing, made more sense and expect it will make marking/drilling with precision a bit easier.
The surfaces shown in the photograph are the only ones with a finish. With my milling table not being operational yet, the narrow side and the ends of the strips were squared off on the U3 and the wide side finished by hand with sandpaper on a glass plate.
Since I do not intend to make them double sided or interchangeable, the other two surfaces will stay as they came from the purveyor.
Best,
JHM
Dave S18/06/2023 07:51:46
433 forum posts
95 photos
The original bar bed Unimat made extensive use of zamak, so as a material for small lathe use Emco already had experience (and presumably a supply chain).
Atlas (I think) lathes in the USA used zamak changewheels, and various other machine parts in various other machines are made of it.
It’s relatively cheap, casts well and is roughly as strong as brass, whilst being slightly softer than iron/steel.
I believe it also has good vibration damping properties.
Michael Gilligan18/06/2023 08:50:41
23121 forum posts
1360 photos
No problem with any of that, Dave … but it doesn't really address its suitability as a sliding bearing material: Which [unless anyone knows otherwise], I would venture to suggest is no better than the hard aluminium alloy which was derided by most posters on the other thread.
Dave Halford18/06/2023 11:14:24
2536 forum posts
24 photos
I don't think the Unimat3 was ever intended to be used a a serious lathe - the 10 fulfils that roll.
Hopper18/06/2023 11:23:01
7881 forum posts
397 photos
Myford lathes use a lot of Mazak (same as Zamak) on peripheral parts such as the motorising unit frame and H frame, belt guards, gear guards, leadscrew brackets, cross slide end bracket and the awful little ML7 cross and top slide dials. But not any of the main moving parts, thank goodness.
I think its main component is zinc, with lesser amounts of aluminum and copper. Never seen it used as a bearing. Always seems to be a brass or bronze sleeve in it, eg Myford leadscrew mounting brackets.
Julius Henry Marx18/06/2023 12:56:00
113 forum posts
52 photos
Hello:
Posted by Dave S on 18/06/2023 07:51:46:
... Unimat made extensive use of zamak ... | ... roughly as strong as brass ...
Posted by Michael Gilligan on 18/06/2023 08:50:41:
... doesn't really address its suitability as a sliding bearing material ... | ... suggest is no better than the hard aluminium alloy which was derided by most posters ...
Posted by Hopper on 18/06/2023 11:23:01:
Myford lathes use a lot of Mazak ... | Never seen it used as a bearing. Always seems to be a brass or bronze sleeve in it ...
@Dave, @Michael, @Hopper:
As an architect by trade and amateur photographer for quite a few years, one of my favourite phrases/quotes has always been "a picture is worth a thousand words", said to be attributed to an advertising executive in the first decades of the 20th. century.
To wit: the photos I am posting below belong to the "taper turning" or "top slide" accessory (part #150 190) that came with my Unimat 3, a part that a firm by the name of Blue Ridge Machinery and Tools at some point had on their Unimat 3 parts catalogue for a cool US$49.00 and these days can command silly money prices. (~ £80/100).
The attachment's base was probably manufactured with the same material as the cross slide and the result of that can be clearly seen in the photograph below:
If that were not enough, while taking measurements prior to attempting to repair the damage, I discovered that the cylindrical protusion than moves/pivots inside the recess in the cross slide has very little material in common with the base itself and was most probably a tad short.
Here is the sketch I made at the time:
As you can see, there is very little material at work to take the stress, something closely resembling a 11.0 x 12.0  x 1.0 mm washer made from Zamak.
How do you say "salt to the wound" in German? 8^°
Fortunately, I eventually managed to figure out a way to repair it with a piece of brass rod, the end result being this:
I have not had a chance to use it as yet, but I expect that once I make a new set of gibs for it, it will work as intended.
I expect these photographs serve as a definite/suitable example of Mazak/Zamak used to manufacture the wrong part, in the wrong place for the wrong reasons.
My thanks you all of you for your input.
Best,
JHM
Edited By Julius Henry Marx on 18/06/2023 14:11:21
Michael Gilligan18/06/2023 17:53:39
23121 forum posts
1360 photos
Please forgive the digression, but I think this current ebay auction is evidence [if any were needed] that Emco Unimat has a certain mystique: **LINK**
https://www.ebay.co.uk/itm/385684950238
Julius Henry Marx18/06/2023 19:26:37
113 forum posts
52 photos
Hello:
Posted by Michael Gilligan on 18/06/2023 17:53:39:
... forgive the digression ...
No problem, today is still Sunday so all is forgiven. But tomorrow is another day, so standard rules apply. 8^)
... Unimat has a certain mystique ...
Indeed ...
Both certain and unjustified, save only because of the hype and the scarcity, combination which turned it into a collector's item.
In the same catalogue I mentioned previously, a ten piece 1.0 to 8.0 mm ES-16 type collet set (part #152 200) was offered for US$375.00 with additional collets (0.5-1.00 mm to 7.0-8.0 mm) went for US$38.50 each.
A small fortune. I don't have a date for the catalogue but I'd wager that it is post Emco discontinuing the Unimat 3.
That said, Emco still has some Unimat 3 parts for sale. Their webpage (German language only) has the newer ESX16 version of the chuck (M14x1 thread) for €63.60.
The original OEM E-16 collets were standard Schaublin fare ie: very good but quite expensive, as all good quality precision tools are.
Emco sill has a 15 piece (?) set of ESX25 collets in 0.5-1.00 mm (?) to 15-16 mm (?) sizes for €180.00 but I don't who the OEM is.
Best,
JHM
Edited By Julius Henry Marx on 18/06/2023 19:29:12
